LSD problem
08-13-2005, 12:13 AM
LSD problem
Kas Wrote:Today, I bought 2 liters of Valvoline gear oil, 75W90, semisintetic, for LSD diferentials, drain out some Gulf mineral LSD oil, and fill it in.
After I change oil, I lift up rear end, run engine, and wihtout any loads, both wheels are spinning.
Try to drift in both sides, and everything is OK.
Thanks Kris, You save to me xxx euros.
Q: Is semisintetic oil good for AE 86 LSD's?
Kas -
did it say LS on the oilpackages ?
if NOT, i´d change the oil to specific LS oil.
& do change the oil one more time very soon.
this is what i did.
08-13-2005, 12:15 AM
LSD problem
I used Royal Purple, the same oil as used in Nascars. It costs 40E/L but i got it pretty cheap...
08-13-2005, 12:28 AM
LSD problem
Kas -
this is what i did.
Yes, it say LS on GULF oil, but my LSD was sometimes work, sometimes not.
Now it work every times.
Today was a rainy day......... I drowe 150 km in town........ the car is CRAZY!!!!!!!!!!!!!
I just love it, old bucket, but so fast, and so good.
1984 AE 86 Levin hatchback
1989 AE 92 GTi
2004 Kawasaki KLE 500
08-13-2005, 12:29 AM
LSD problem
Remember to change the oil every 20000 kms... ATLEAST Thumbs up!
08-13-2005, 12:34 AM
LSD problem
Knudsen Wrote:Remember to change the oil every 20000 kms... ATLEAST Thumbs up!
Of course. Nox time, i'll change LSD oil after winter, it is not to expensive.
Today, when I drain oil after only 2500 km, on magnetic screw was about 2-3 mm of worn material.
A little bit much, but OK.
1989 AE 92 GTi
08-13-2005, 12:41 AM
LSD problem
I wont even tell you hov much there were on my magnetic thingy... I dont think the oil in my diff has been changed since 1998 when the car had 55000 kms on it... thats 90000 km ago Angry
08-13-2005, 10:41 AM
LSD problem
I change my oil every 10kSmile Engine needs to last my punishment!Smile
*edit* smart thing whenever buying a hachi, first thing you do: replace ALL fluids, coolent, motor, gearbox, LSD, thats the only way you know for sure your car will stay healthy. There is nothing worse then having your car break down and find out they put plain h2o in as your coolent, or used the wrong diff oil, or your synchros are eaten away because of the wrong gearoil...
  4agZe problem solved - 99% IC problem Okami 41 35,615 07-12-2012 04:49 PM
Last Post: Okami
  AC problem? Idle problem? KD2229 3 4,742 08-19-2009 02:08 AM
Last Post: KD2229
  Upgrading no-LSD diff to LSD one Snejk 22 18,146 04-01-2008 04:46 PM
Last Post: Snejk
  Problem with TOMEI LSD joaotcgt 16 14,095 11-27-2006 10:38 AM
Last Post: Mux213
  Not understanding LSD - how LSD works surfingdrums 11 15,876 09-13-2006 11:58 AM
Last Post: Mux213
