LSD problem
08-13-2005, 12:13 AM
LSD problem
Kas Wrote:Today, I bought 2 liters of Valvoline gear oil, 75W90, semisintetic, for LSD diferentials, drain out some Gulf mineral LSD oil, and fill it in. Kas - did it say LS on the oilpackages ? if NOT, i´d change the oil to specific LS oil. & do change the oil one more time very soon. this is what i did. I´m sorry sir, your planet has been sceduled for destruction in favor of an intergalactic highway -Thank you Kristian Hesselmark, Sweden EVO-DRIFT-STREET-DRAG-SHOW |
08-13-2005, 12:15 AM
LSD problem
I used Royal Purple, the same oil as used in Nascars. It costs 40E/L but i got it pretty cheap...
08-13-2005, 12:28 AM
LSD problem
KristianAE86 Wrote:Kas Wrote:Today, I bought 2 liters of Valvoline gear oil, 75W90, semisintetic, for LSD diferentials, drain out some Gulf mineral LSD oil, and fill it in. Yes, it say LS on GULF oil, but my LSD was sometimes work, sometimes not. Now it work every times. Today was a rainy day......... I drowe 150 km in town........ the car is CRAZY!!!!!!!!!!!!! I just love it, old bucket, but so fast, and so good. 1984 AE 86 Levin hatchback 1989 AE 92 GTi 2004 Kawasaki KLE 500 CROATIA - small country for great drift |
08-13-2005, 12:29 AM
LSD problem
Remember to change the oil every 20000 kms... ATLEAST
08-13-2005, 12:34 AM
LSD problem
Knudsen Wrote:Remember to change the oil every 20000 kms... ATLEAST Of course. Nox time, i'll change LSD oil after winter, it is not to expensive. Today, when I drain oil after only 2500 km, on magnetic screw was about 2-3 mm of worn material. A little bit much, but OK. 1984 AE 86 Levin hatchback 1989 AE 92 GTi 2004 Kawasaki KLE 500 CROATIA - small country for great drift |
08-13-2005, 12:41 AM
LSD problem
I wont even tell you hov much there were on my magnetic thingy... I dont think the oil in my diff has been changed since 1998 when the car had 55000 kms on it... thats 90000 km ago
08-13-2005, 10:41 AM
LSD problem
I change my oil every 10k Engine needs to last my punishment!
*edit* smart thing whenever buying a hachi, first thing you do: replace ALL fluids, coolent, motor, gearbox, LSD, thats the only way you know for sure your car will stay healthy. There is nothing worse then having your car break down and find out they put plain h2o in as your coolent, or used the wrong diff oil, or your synchros are eaten away because of the wrong gearoil... Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
4agZe problem solved - 99% IC problem | Okami | 41 | 35,615 |
07-12-2012 04:49 PM Last Post: Okami |
AC problem? Idle problem? | KD2229 | 3 | 4,742 |
08-19-2009 02:08 AM Last Post: KD2229 |
Upgrading no-LSD diff to LSD one | Snejk | 22 | 18,146 |
04-01-2008 04:46 PM Last Post: Snejk |
Problem with TOMEI LSD | joaotcgt | 16 | 14,095 |
11-27-2006 10:38 AM Last Post: Mux213 |
Not understanding LSD - how LSD works | surfingdrums | 11 | 15,876 |
09-13-2006 11:58 AM Last Post: Mux213 |
