Leaking sunroof...
01-30-2005, 10:58 PM
Leaking sunroof...
Does anybody know where i could find the rubber seal for my pop-up sunroof? It started to leak when it's raining. The type is
FARMONT TECHNIK Type : JUWEL KBA 9306 If i can help you a Farmont dealer in Athens said that the code for that is 1320 but he doesn't have it and he won't have it in the future. Anybody can help? Thanks in advance AE86 FANATIC!!! |
01-31-2005, 10:47 AM
Leaking sunroof...
Join the club man...I have a Farmont roof as well, it leaks like hell and there is little I can do about it.
01-31-2005, 12:00 PM
Leaking sunroof...
Ivan do you know if it's possible to swap my sunroof with the electric one from a donor car GTS TRUENO?
It seems to have the same dimensions with mine (measuring then on the cars). Have you ever heard of such a project? AE86 FANATIC!!! |
01-31-2005, 01:03 PM
Leaking sunroof...
Nope, but I think it's a bit difficult. You can only install it if the existing hole in your roof is smaller or exactly the same size. I think it folds under the roof so there might be some more room under the roof on models fitted with it.
01-31-2005, 01:27 PM
Leaking sunroof...
Ok Ivan!
Thanks a lot anyway AE86 FANATIC!!! |
Sunroof clips | FanIsHere | 0 | 4,015 |
08-19-2016 11:33 PM Last Post: FanIsHere |
brake line leaking - how to fix ? | MC_JP | 2 | 4,303 |
04-28-2014 09:47 PM Last Post: MC_JP |
Sunroof Controller Diagram | Serencebey | 2 | 4,752 |
02-24-2010 05:11 PM Last Post: Serencebey |
problem again , about leaking half shaft bearing | filh | 10 | 10,078 |
03-22-2009 01:03 AM Last Post: filh |
Oil leaking from top but its not broken ??? | Allexz | 4 | 4,685 |
05-09-2008 07:48 PM Last Post: nikos_trd |
