Leaky heater control valve?
03-13-2012, 05:40 PM
Hello Everyone,
I recently purchased a 2 door Levin that had a little oil leak from the oil filter, after changing the oil filter and fixing the leak I noticed that there was some coolant dripping from the back of the engine bay. I followed the fluid up to a pipe next to the clutch fluid reservoir, the pipe goes into what i can only describe as like a metal disk (flying saucer shape) thats bolted to the bulkhead.
Does anyone know what this could be? and if so where can I get a replacement part?
Thanks in advance!
  4A-GE valve shim disintegrated DaLanZhu 2 1,768 04-30-2025 12:54 PM
Last Post: DaLanZhu
  4AGE Valve Buckets Scored Steller Engineering 2 2,019 10-06-2023 05:34 PM
  20 Valve Blacktop smoking after engine flush - why? RolanTHUNDER 2 3,103 11-30-2022 12:09 PM
Last Post: RolanTHUNDER
  HKS valve springs totta Crolla 3 3,656 05-25-2022 10:24 PM
  Valve clearance leon205gti 7 10,397 11-25-2016 03:24 AM
