Lets play "Guess that sound!" aka diff problems
08-27-2010, 04:07 PM
Theres so much ratlle coming from the back I need to set those brake pad springs properly, so there is also alittle disc squeeling. Today a new exhaust has been made. quite a good job bi i think its hitting the trailing arm mount on the rear axle.. Any familiar sounds guys? |
08-27-2010, 04:31 PM
Im hearing the sound that is similar to sticking a cardboard in the spokes of a bicycle and riding it.
Sounds like a Chipped pinion or CW tooth. Stop driving it. http://www.skynet.ie/~eireae86 |
08-27-2010, 05:21 PM
Thanks for your input, it might indeed be that. The car is driven only to get it from shop to shop, fixing things up for MOT. I was planning to deal with the diff later, hope this isnt so bad:/
Man in the end i will need to replace every f. thing on this car |
08-27-2010, 09:48 PM
I think it must be worn out / burned diff bearing. that tone of voice isn't belongs to the cwp.
08-27-2010, 10:31 PM
http://www.bilgalleri.dk/vid_vis.aspx?VideoID=34214 my buddys ae86, almost evry tooth on cwp was gone..
08-28-2010, 01:19 AM
wow it isnt quite as bad as that, but something is up for sure. i get the worst noises if i gently tap the throttle at very low speed. like trying to bob the car forward..
Big wheel problems | gh0st | 16 | 7,974 |
Starting problems 4-AGE kouki | Hanzo | 3 | 2,574 |
Play between steering column and intermediate shaft after manual rack sonversion | DaLanZhu | 5 | 6,660 |
Lets talk engine mounts | kazi | 6 | 7,628 |
08-31-2017 12:46 PM Last Post: parrot |
Problems Mintex M1155 pads | Dino86 | 9 | 8,765 |
07-04-2017 11:22 AM Last Post: totta Crolla |
