Levin Coupe from Croatia - NOW SR86 with IRS
09-21-2004, 10:29 AM
[Image: AEU86 AE86 - Levin Coupe from Croatia - ...6 with IRS]
New car!
Specs:
Ride:
86 Toyota Corolla Levin Coupe AE86 white
VIN: JT1S0AE86 0012582
Owner
ZaX
Under the hood:
1991 4A-GE AE92-Kouki Red-Top engine,
16V 1595ccm, small port, no TVIS, 235ccm injectors,
Adjustable cam pulleys
Cometic gasket set
New thermostat
New water pump
NGK R plugs
BMC F1 air filter
Straight through exhaust
JUN type exhaust, made by Lastovcic
TRD oil cap
Increased holding capacity clutch kit
Mintex racing braking pads, 1144 compound
Mintex racing braking oil, 312°C boiling point
Stiff stuff: Front
Paradise racing coilover kit with 8kg/mm QA1 springs
Koni Sport yellow adjustables front with short stroke conversion (AE92)
T3 camber plates, runnin -3° camber and 3° of caster
Jubiride Roll Center Adjusters 30mm
MOMO 20mm wheel spacer, hub centric
Prothane bushing kit allaround
Rear
Koni Sport yellow adjustables in the rear
6kg/mm spring
Adjustable panhard rod
Dual swaybar mod
Custom 25mm wheel spacer, hub centric
Rollers:
15"x7" ET0 Konig rewind, graphite with polished lip
15"x7" ET32 Mesh alu wheels
15"x7" ET37 Postert alu wheels
14"x7" ET21 Intra Toyota OEM
13"x5,5" Pizza cutters Toyota OEM
TOYO Proxes T1-R 195/50/15
TOYO Proxes T1-S 195/50/15
Barum Polaris 165/70/13 Winter tires
Tire Flys
TT +20mm wheel studs
Enkei Sport wheel nuts
Outside: Zenki lip
Denso wipers Smile
Yellow fog lights
Inside:
Striped out interiour
Heigo 7 point roll cage
Sparco Evo red seats, FIA homologated
Schroth 4 point harnes
Nardi steering wheel
75mm Steering Hub Extension
Nardi gear knob
Delrin Shift Bushing
Custom short shift kit
Cusco spin turn knob
VDO Oil preasure gauge
VDO Oil temperature gauge
VDO Voltmeter
ICE
JVC CD-player
One OEM speaker
My ride build up:
First service
4l 100% synth
4 NGK spark plugs
1 oil filter
1 air filter OEM
2 Denso wiper
2l LSD oil
Old spark plugs Sad
Clutch change
Seats are in. Sparco Evo.
Cat was removed. Smile
Before
After
"box"
Springs 450lbs = 8kg/mm, sleve,camber plates
new spring vs old spring
Before
After
Stage I finished.
waiting for koni short stroke adjustables, rca's, bushings...
Cleaning of bearings
Cleaning of brakes
Brakes, w8ing 2 install
Springs: coilover sprig 8kg/mm, front stock vs 6kg custom, rear stock vs 4kg custom made
Suspension, plastificated not painted
United Colors of Benetton
Koni Sport adjustables shocks, top = AE86, down = AE92 aka. short stroke
Difference in lenght
09-21-2004, 10:31 AM
...continued...
Cuted struts 40mm
Pictures:
Top = original AE86 Koni, don't fit any more Smile
Down = AE92 Koni shocks, "too short" Smile
i used old bushing from sway bar as a spacer under the koni shocks
Bushing that was inserted
With bushing inserted under shocks, there is no more movement inside the sturt case
...continued...
Cuted struts 40mm
Pictures:
...continued...
Cuted struts 40mm
Pictures:
Before
Preview of new exhaust.
[Image: AEU86 AE86 - Levin Coupe from Croatia - ...6 with IRS]¸
09-21-2004, 10:32 AM
New toys
(Before, duck tape racing exhaust)
Now ->
Jun-type straight-thru, under diff exhaust
Flexibile pipe
Momo corse red, steering wheel
Nardi torino leather shift knob
JDM style drift hood Smile
Long studs, ordered from Japan
MOMO 20mm spacers
Old studs vs New studs (+20mm)
Pressed in new studs
Disc
+ spacer
+ spacer + spacer...um... no Smile
Rain is falling outside, so i'm waiting it to stop, so i can continue my work.
Pics later.
09-21-2004, 10:33 AM
Spacers in front
Testing
Low life.
Now i have to lower the rear end aditionaly.
Mobikrog 15.8.
AE86 in action - first time!
09-21-2004, 10:34 AM
And, another thing. I swaped my bimmer for S13 CA18DET 170Hp, no LSD (yet Smile ), nice condition.
Here are the pics.
Now i have AE86 white + red parts car, S13 silver + red parts car.
09-21-2004, 10:36 AM
My ex bimmer
Now
09-21-2004, 10:38 AM
Newest addition to my silver S13
Preparing side skirts for my ae86, roll center adjusters, mintex racing pads, motul racing brake oil....lots to do, so little time. Smile
09-21-2004, 10:42 AM
What a thread! Huh :o Big Grin
Just loove all that AE86 goodie-goodie and all them lovely pics! Big Grin
Goood work! *all thumbs up*
Best Regards,
09-21-2004, 10:47 AM
Whow Zax!
Some of those pictures I saw on club4ag I think. You are really putting some work in that hachi of yoursSmile
Dont you get into trouble with your fenders with that low and wide setup?
Whaa, this is absolutely a 56k killer. Tongue
The muffler looks great on your car! Smile
  Trueno Hatch and Levin Coupe - Repair, replace, pray xD TomRich 13 22,644 10-07-2018 09:45 PM
  @dodo@ Levin Coupe, renovation and tuning (56k think twice) @dodo@ 165 216,330 03-28-2018 12:35 PM
  Aram's 3SGE Beams Levin Coupe robokill 665 940,173 09-03-2017 09:24 PM
  Matt's "Drives as fast as it's Towed" 85 Levin Coupe mad.matt 38 54,920 04-07-2016 12:15 PM
  DidiDex 1984 Levin coupe rebuild DidiDex 1 7,710 08-13-2015 03:22 PM
Last Post: DidiDex
