Levin Coupe from Croatia - NOW SR86 with IRS
12-06-2005, 03:25 PM
Post: #291
Bearing for the rear axle. Just pictured Wave
Fun is not the straight line!
12-06-2005, 03:41 PM
Post: #292
Damn ZaX Thumbs up! Thumbs up! Thumbs up! Thumbs up!
[Image: AEU86 AE86 - Levin Coupe from Croatia - ...6 with IRS] http://www.jdmbits.com
12-09-2005, 03:57 PM
Post: #293
Nice ZaX!
12-18-2005, 06:00 PM
Post: #294
After a bussines trip this week, I finally got some time to work on the car.
I instaled the thermostat since car didn't have one. Car wouldn't warm to working tempertaure and it was cold inside these days. Somebody instaled 2 or 3 gaskets so I had to use dremel tool to clean up the surface on water pump to prevent leaking.
Other then that I replaced my windscreen wipers with new ones, replaced cable for openin the hood, since old one broke, mounted the front mask and mounted the front license plate.
I still have to fix side indicators fuse, horn, rear glass heater, co-drivers doors...
It's cold to work in garage so I doubt i'll do anything in next days.
Also rebuilt spare rear brake calipers so I can fix everything on the rear axle when I'll be doing the LSD and bearings rebuild.
12-18-2005, 06:26 PM
Post: #295
Zax, get one of those cheap small electric fan heaters. They work pretty good if you place them near you and let them blow hot air at you. I use one in my shed and it heats up the shed relatively quickly..
12-18-2005, 07:04 PM
Post: #296
mux213 Wrote:Zax, get one of those cheap small electric fan heaters. They work pretty good if you place them near you and let them blow hot air at you. I use one in my shed and it heats up the shed relatively quickly..
TE71Corolla used a single one to dry/heat his TE71 when he put it in primer. Big Grin
And it is indeed a very cheap option: you see those things for only 15 euros nowadays. Smile
12-18-2005, 10:15 PM
Post: #297
ZaX Wrote:
Ivan141 Wrote:How much did you pay for the SKF bearings?
bearings for the rear axle and diff:
12? LM501349/10 KOYO x 2
16? M86649/M86610 SKF x 1
18,5? HM88649/10 SKF x 1
Total 58,5?
ZaX, do I have to change all bearings, both for diff and axle?
Which ones are for the diff only, the SKF or the Koyos?
12-18-2005, 10:28 PM
Post: #298
Total 58,5?
Man, use your brain cells, not nmwisima's ass. Tongue
2 same bearings = one for each axle = koyo
2 different ones = for diff = skf Wave :wink:
12-19-2005, 11:25 AM
Post: #299
Stupido ZaX, I got problem and cant see the pictures...
12-21-2005, 04:37 PM
Post: #300
OK, as I writen elsewhere I bought another hachi.
Description: blue metalic AE86 zenki GT, Bluetop 4A-GE MAP engine, 201k km on oddo, car is dented and scratched everywhere. There is no good panel on it. Doors, hood, hatch is rusty, sideskirts have big holes, all 4 fenders rusty, position lights broken, rear lamp broken, sunroof is bad, all seats have holes in them, there is no key (half of it is broken in lock) so no steering at the moment, windshield is broken....
I'll post the pics now, some of them from the morrning. Later I washed the car so it looks bit better now.
  Trueno Hatch and Levin Coupe - Repair, replace, pray xD TomRich 13 14,584 10-07-2018 09:45 PM
  @dodo@ Levin Coupe, renovation and tuning (56k think twice) @dodo@ 165 158,630 03-28-2018 12:35 PM
  Aram's 3SGE Beams Levin Coupe robokill 665 723,168 09-03-2017 09:24 PM
  Matt's "Drives as fast as it's Towed" 85 Levin Coupe mad.matt 38 39,415 04-07-2016 12:15 PM
  DidiDex 1984 Levin coupe rebuild DidiDex 1 5,340 08-13-2015 03:22 PM
Last Post: DidiDex
User(s) browsing this thread: 251 Guest(s)
