Lights - How to turn these on
07-14-2008, 03:51 PM
I thought they would be side lights also... as they dont seem to be high intensity lights as fog lights should...
My Hachi Roku
07-14-2008, 04:19 PM
thats some weird stuff banpei.
so the white light go on once you use the turn indicators? why? so you have light going through the corner? Tongue
07-14-2008, 04:54 PM
No the lights don't come on at all, no matter what combination i use with the controls...
...I'd like to identify what the lights are sidelights, fogs, indicators...
My Hachi Roku
07-14-2008, 06:50 PM
this kind of lights u have u have to wire ur self like u want
go to the electric or mechanic and say to him i want that when i push here light this and etctcetcetcet
cause if u run a AE86 painted like apanda u have to get the simple form
of the fogs and lights
my opinion ans mode that im going to set in mine
1st clik - just the little one (the close ones to the trueno emblem)
2nd clik -pop up light or the main lights and the little one still on
3rd clik - press and turn and the main lights and the little ones have to turn off but the pop up lights have not to be closed
in th eleft of the steerin wheel there a special button for the fog light (big yellow one inisharu di style
and the next to the little ones i mean the oranges ones just for directional
but i think u know all that
please bunpei if u canhelp me can u tell me the size in milimeter(mm)
just the siz eof the the orange ones horizontal and vertical and prodfundity
if u can send me a picture of that will be great
but just the orange in total cause i liek the inital d style with out the white lamps cause im gonna do it homemade but try to do it same as the original but the probelm is the last owner brake all the front bumper and
did not have them when i bought it so i m in zero i just need a good picture and the measure to make them
and fixing the front bumper right now
bunpei can u send me that measures or photo?
or anyone else have the measure
07-14-2008, 07:52 PM
So they should come on with the indicators?
My Hachi Roku
07-14-2008, 08:47 PM
I can't send you the size or photo: it's not my car in that video. Tongue
Perhaps someone else can give you those measurements and pictures can be found plenty on this forum. Wink
[Image: AEU86 AE86 - Lights - How to turn these on]
07-14-2008, 09:27 PM
The orange little ones SHOULD light when the corner whites light up!
I have the exact same lights in my trueno, but since I have "originally" a levin with levin wiring loom, i had to make some "figuring out" Tongue
Corner whites I connected to levin corner lights, main blinkers to levin blinkers and small oranges after a few frustrating experiences, I wired back to the corner whites.
07-15-2008, 12:04 AM
Okay thanks.
I've rewired it so that now the small orange ones are swapped with the corner ones so now the corner lights are the side lights. the small ones aren't lighting up for the time being.
the plug for the lights is as follows.
[code:1:3f2058f40c]
Loom end
[G ][YG]
[YR][BW]
G = Green = Side lights
YG = Yellow-Green = Indicators
YR = Yellow-Red = Corner Lights
BW = Black-White = ???
[/code:1:3f2058f40c]
My Hachi Roku
07-15-2008, 01:19 AM
as far as I know, there is a special way of connecting it. I'm looking for the diagram or instructions on how to do it.
Pedro Velado
GT-S Owner
07-15-2008, 11:09 PM
These lights are cornering lights on Kouki AE86 (85-87) Trueno and should work on single side indication only not Hazards like the above video. The proper bulbs are 12V 35W. As said above the small orange lamp section is parking light and the big orange lamp section is indicator. These lamps should only in conjunction with position 2 on the light switch i.e. headlamps up and on and when you indicate. Can you hear a relay clicking off about 3-4 seconds after the indicator cancels as that is the delay between indicator cancelling and cornering light switching off. Kouki Levin also has this function in the sidelights that's why they have twin filament bulbs in Jap Levin's sidelights.
  Can you seperate trueno kouki bumper lights into zenki bumper lights? gh0st 17 9,010 12-19-2021 11:58 PM
Last Post: gh0st
  Start wont turn over after installing radio MC_JP 6 10,137 09-22-2014 11:13 PM
Last Post: izanagi
  Are these modded TRD N2 flares? 4000GT 6 18,806 06-21-2014 12:16 AM
Last Post: 4000GT
  What injectors are these? Alex170984 4 6,107 08-05-2013 11:53 AM
Last Post: jondee86
  Prothane, are these any good? Eric 16 14,768 09-11-2011 05:17 PM
Last Post: xgrapher
User(s) browsing this thread:
