Limp mode
10-07-2021, 09:35 PM
(This post was last modified: 10-07-2021 09:38 PM by Eddy Lau.)
Limp mode
Hi , am new to the ae86, and my Trueno ran perfectly until recently.
It got itself into limp mode I think. I can’t rev over 3000rpm and the check engine light come on as if I hit the limited. If I let off the throttle, the revs dropped and check engine light goes off too. It ran smoothly and sweet below 3000rpm everything is as it should no problem in starting. I did a diagnostic test and the codes 3 , 5 and 9 came up. 3 is the Ignition signal to ecu 5 is the oxygen sensor 9 is the vehicle speed signal to ecu which does not trigger a CEL My question is does the fault code 3 or/and 5 trigger the limp mode or there might be other reason? A new oxygen sensor is on order but not sure what parts to replace regarding the ignition signal to ecu. Any help is appreciated. |
10-07-2021, 10:06 PM
Limp mode
I'd say the ignition signal issue is the most urgent one. That comes from the distributor if I'm not mistaken.
10-07-2021, 10:13 PM
Limp mode | |||
engine wont go into diagnostic mode with T&E1 bridged | Bean | 8 | 10,420 |
05-30-2010 08:31 AM Last Post: totta Crolla |
User(s) browsing this thread:
