Longer studs
04-28-2011, 09:50 PM
Longer studs
fornt and rear, were do i get a set without having to measure all out myself.
Just a set ready to go, off the shelf, as long as possible. |
04-28-2011, 10:12 PM
Longer studs
Eric, I think this should fit.
http://www.biesheuvel.nl/store/product/2...gte__67_mm jamiemirror post the OEM stud spec here.
04-29-2011, 03:14 AM
Longer studs
I recently replaced the front ones, I got them off ebay, but it needs a bit of looking around, to find what you want.
Specs and price were similiar to the shop given in the previous post. You´ll also need open wheel nuts. 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
04-29-2011, 07:35 AM
Longer studs
Danke
![]() Open nuts in no problem, i van get them everywere. Ill give biesheuvel a call. |
| ARP Head studs in a N/A engine, necessary? | Jimmi The Kid | 13 | 17,695 |
02-04-2013 11:27 PM Last Post: Jimmi The Kid |
| Longer 5th gear into T50 | stratosTRD | 3 | 5,741 |
06-16-2011 08:36 PM Last Post: stratosTRD |
| longer wheel studs | fax0815 | 8 | 12,363 |
02-17-2011 09:57 AM Last Post: max_ae86 |
| How to fit rear wheel studs without removing the shafts? | Slipangle | 3 | 5,953 |
11-19-2010 10:29 PM Last Post: Slipangle |
| Longer Tie rod / steering ends | meshin | 2 | 6,838 |
11-10-2010 01:57 PM Last Post: meshin |
