MAP Harness help
07-07-2007, 06:56 AM
MAP Harness help
No diagram, but if you were staring into the end of the half of the plug
that is connected to the engine side of the loom (connecter clip to the left and locating lugs top and btm on the right) you would see this : [1] [2] [3] [4] [5] [6] [7] [8] [9] These numbers represent the three rows of three pins inside, which are : 1. Backup (reversing) light switch 2. Backup (reversing) light switch 3. Spare pin 4. Igniter power supply (black/orange wire) 5. Power supply to injectors (yellow wire) 6. Starter/cold start injector 7. Water temp gauge (on instrument panel) 8. Oil pressure gauge (on instrument panel) 9. Tacho (rev meter) signal Hope your plug looks like this ![]() Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
07-07-2007, 04:06 PM
MAP Harness help
Thanks ill have to check it out hopefully i can get this working =D
- Fuzzy |
07-12-2007, 12:50 AM
MAP Harness help
Is the UK harness the same as the Japan one?
- Fuzzy |
07-12-2007, 02:05 AM
MAP Harness help
heres a pic of the connector im talking about
![]() - Fuzzy |
07-12-2007, 09:44 AM
MAP Harness help
Ohhhhh.... kaaaayyy then.... not likely that you will see one of those
plugs on the firewall ![]() that should have a matching socket close by the ECU. If the accessory plug on the loom doesn't match the one beside the ECU you will have to swap the plugs and match up the wires. Your plug doesn't match mine, so I can't help much. But for your information, I did identify these items on my car as leading back to the accessory plug : 1. Wiper motor (3 wires) 2. Washer motor (2 wires) 3. Variable resisitor (1 wire) (used on AE86 without O2 sensor) 4. Spare plug on engine loom (1 wire) 5. Plug beside underhood fusebox (1 wire) (can't remember what it did) AFAIK the accessory plug in your pic has nothing at all to do with the plug on the engine side of the firewall as described above ![]() Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
AFM to Map Conversion | ps13michi | 3 | 3,456 |
Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP | mister86 | 12 | 11,520 |
AE86 4A-GE 16v engine harness rebuild | FanIsHere | 7 | 10,485 |
extracted freedom ecu 16v ignition map | ditn | 7 | 9,135 |
anyone produce new harness for bluetop?gts driveshaft | dinkers542 | 8 | 8,482 |
11-25-2014 09:18 PM Last Post: dinkers542 |
