MAXGRIP 7.5" Supra LSD kits
03-17-2009, 07:41 AM
MAXGRIP Supra 7.5". A real performance rebuild kit for the O.E.M. Supra LSD. These parts have been designed to get the maximum grip possible with the o.e.m. LSD! The kit comes with new stationary plates and new clutch plates that were normally not installed from the factory. Adding these two clutch plates increases the overal friction surface area 4X or 200% more than the typical factory LSD. Also included are new reversible solid bronze thrust washers, spiral grooved for oiling. You also get new heavy duty springs and complete shim kit (16 assorted thicknesses) for setting the clearances within the LSD to exact specs for best performance. Using this kit, your LSD will be more responsive, lock faster, with maximum grip! No more one tire fire!
![]() This is a great alternative to the more expesive aftermarket LSD's! We also have a kit for the O.E.M. GTS LSD and plan on producing kits for Mazda and others soon. Since this LSD is very similar to the AE86 you can use the install instructions for the MAXGRIP GTS kit: http://forums.club4ag.com/zerothread?id=31135 $190.00 plus ship and CA sales tax if applicable. Thanks! Spence Weir Weir Performance Engineering LLC 707-315-6638 Spence_weir@sbcglobal.net |
Group A --- Body Kits Jblood, Vertex, RunFree, Goodline | Group A | 20 | 40,242 |
03-20-2013 10:01 PM Last Post: alimonos |
Wilwood Brake Kits €600 each | ep71 | 14 | 34,925 |
01-18-2013 01:04 AM Last Post: TheGerman |
Track and road brake kits | ep71 | 12 | 15,917 |
09-17-2012 10:28 AM Last Post: ep71 |
MCNSPORT.com FRP & CarbonFibre Products - Prices & P | MCNSPORT.com | 49 | 68,345 |
09-16-2009 04:26 PM Last Post: MCNSPORT.com |
P.A.S.S - D-Max, Runfree, Vertex, CBY, Goodline, Jblood KITS | SYM | 41 | 58,569 |
07-31-2009 11:20 AM Last Post: SYM |
User(s) browsing this thread:
