Main clutch cylinder?
08-21-2007, 04:59 PM
Hello Wink
Got a problem now with my hachi Dumb question Clutch fluid is leaking into the interrior through the main clutch cylinder as I understand (that one, near the pedals) . I had same situation about half a year ago, but clutch cylinder repair kit solved my problem. When I took that cylinder out of my car I was told, that it is in bad condition, and the repair kit will help only for a year (that's maximum)...
So, it happened again, and now i want to change that cylinder. Today I visited few japan-cars parts shops, and there were no such part as "main clutch cylinder" for 84` corolla GT (very rare car here Confused ) Crying Maybe there are any clutch cylinder from other car (ae92? ae82? celicas?), that suits for ae86?
White ae86 Levin
08-21-2007, 06:34 PM
Try Ebay...you can often find stuff like that at okay prices there..
08-22-2007, 04:51 PM
Yeah, found exhatcly what I need. But there is one point, that I don't like:
Quote:Application:
Toyota Corolla Rwd
8/1985 - 7/1987
My hachi is a bit older... Made on 1984. Will it fit? (I think it should..) Smile
White ae86 Levin
08-22-2007, 07:33 PM
Yes...it should fit without problems afaik.. The original kouki item even has a better design.
08-22-2007, 10:07 PM
Perhaps we can manage to source it through the shop as well. Smile
[Image: AEU86 AE86 - Main clutch cylinder?]
08-23-2007, 04:14 AM
The guy on US ebay is selling OEM Toyota branded BRAKE master cylinders to suit LHD cars (brake line outlet on the nose goes upwards). They have the Toyota casting ground off. Possibly same story with the clutch masters.
08-23-2007, 05:23 PM
When you cant find the part you need (without toyota ripping you a new asshole with their prices), the fact that something is not OEM suddenly loses a lot of relevance.
If it's the original kouki toyota item, it should have an inline bushing in the pushrod (a cilindrical metal casing), the housing is also slightly different.
08-23-2007, 10:53 PM
I bought a quality replacement clutch master cylinder just recently, and
it was manufactured in FRANCE !!!! Exact replacement, and works just
like OEM, for only 25% of the Toyota price Smile
Cheers... jondee86
08-24-2007, 01:45 AM
When I bought the brake master off that guy, it only cost me USD$85 landed in Australia. Then I stripped it and installed all the seals, rods, springs, fluid reservoir etc into my MC body, only because I have a brake MC stopper which would not work with the USDM MC (which is a little shorter).
In Australia, if you can find a kit or replacement MC, they are very expensive and that isn't from Toyota.
I believe the left and right hand drive clutch masters are identical in configuration so I would happily get one of the US ebay guy in future as his service was great and the product obviously perfect.
  4AGE cylinder head plug removal Ivan141 5 1,999 09-30-2023 09:47 PM
  Brake advice - master cylinder mannix20vt 12 13,871 08-21-2017 03:21 PM
Last Post: Project D
  Peculiar headlight issue - main beam Jezza_hr 3 5,674 10-04-2015 09:25 PM
Last Post: Jezza_hr
  Correct connection brake master cylinder? bozu 5 7,156 07-26-2015 12:28 PM
Last Post: bozu
  torque setting head cylinder bolts izanagi 1 4,860 05-29-2015 01:23 AM
