McKenney's 1UZFE Kouki Levin Coupe
03-12-2013, 04:48 AM
So basic rundown:
1987 USDM Corolla GTS
1987 Kouki JDM Levin front end
MR2 manual rack with AE86 power steering tie rods
power steering knuckles
Hondarue BigBrake adapter kit
FC3S front calipers and pads
Mini Cooper S rotors redrilled for AE86 hubs
NEW stock rear calipers, pads, and rotors
OEM Toyota ebrake cables
P.A.S.S. Racing front coilovers
Bilstein shocks and strut cartridges
Swift springs 9.5kg front, 6.5kg rear
T3 panhard rod for Celica Supra 7.5" diff
Celica Supra 7.5" diff w/ 3.91 gears
MK3 W58 w/ MK2 striker arm and shifter base
Soarer shifter
Exedy Stage 2 clutch for 1995 4runner/Hilux Surf w/ 3vze
1992 SC400 1UZFE w/ LS400 oil pan and pickup
Hondarue EGR delete plates
Xcessive manufacturing 1UZFE/W58 into AE86 brackets and crossmember
1uzfeswapkits.com trans adapter and flywheel kit w/ internal slave cylinder and braided lines
S13 brake master cylinder
Hondarue booster delete plate
Hondarue 2" subframe spacers
1987 Landcruiser clutch master cylinder (3/4") bore
Scirocco aluminum radiator
New front LCAs
stock GTS front sway bar
OEM tension rods
Cusco RCAs
And for some eye candy:
[Image: AEU86 AE86 - McKenney's 1UZFE Kouki Levin Coupe]
newtoy4 by McKenneyLevin, on Flickr
030112151100 by McKenneyLevin, on Flickr
spacerfinal by McKenneyLevin, on Flickr
Untitled by McKenneyLevin, on Flickr
03-12-2013, 04:53 AM
I have a full build on 86garage.com. you'll have to register and make an introduction to view the full site. My build thread is located here after you've registed:http://www.86garage.com/forums/viewtopic.php?f=42&t=4997
There's a lot of trial and error in the build thread, and 15 pages of it too. I gave aeu86.org the abridged version lol. Hope you enjoy the read and the pics.
  Trueno Hatch and Levin Coupe - Repair, replace, pray xD TomRich 13 15,863 10-07-2018 09:45 PM
  @dodo@ Levin Coupe, renovation and tuning (56k think twice) @dodo@ 165 165,903 03-28-2018 12:35 PM
  Aram's 3SGE Beams Levin Coupe robokill 665 758,013 09-03-2017 09:24 PM
  Matt's "Drives as fast as it's Towed" 85 Levin Coupe mad.matt 38 41,851 04-07-2016 12:15 PM
  DidiDex 1984 Levin coupe rebuild DidiDex 1 5,660 08-13-2015 03:22 PM
Last Post: DidiDex
