Megasquirt files and tune!
03-10-2008, 12:19 AM
Hi everyone. I have bought a MS v2.2 for my car.
So i want help to tune it. everything on the engine is stock so i need a basic map for ignition and fuel. And everything else that im missing.
Im new so pleace a normal language Big Grin
And if u got tips how to tune w MS teach me Tongue
Thanks!!
Don´t Think About The Past,
Live In The Present And
Dream About Tomorrow
First narrow or wide band lambda?!
What do i need?
im driving the MAP style
03-10-2008, 07:28 PM
wideband is best for tuning purposes, shows fuel mixture in both rich and lean conditions. It is more expensive though.
Look for 4age maps on the megasquirt forums (http://www.msefi.com ?).
If I were you I'd stay with stock ignition for a start.
03-10-2008, 10:51 PM
i dont have any stock ignition.
got everything setup for ms w the distributor.
03-11-2008, 11:06 AM
Allexz
I believe it is what Ivan means.
You are using the distributor and the original igniter right? Only one wire from the distributor to the MS, and one from MS to the igniter.
Regards
Lars Veiss, Denmark
03-11-2008, 04:00 PM
right. i just need some 4age 16v files to work with. anyone who can help?
really wud like to start my car.
anyone knows the stock cc on the injectors on the bigport 88- tvis engine?
03-11-2008, 08:18 PM
Like I said, there are some floating around on the msefi forums, and probably on club4ag where more people are using megasquirt. I meant use the stock ECU for ignition if you can, but if you dont have it then just use megasquirt with the distributor.
03-12-2008, 06:42 PM
[Image: AEU86 AE86 - Megasquirt files and tune!]
This is the table ive got
03-12-2008, 08:19 PM
i made another one,. from the calculate program in MS
  Megasquirt I v3.0 and toyota distributor/igniter harkes 12 34,806 10-02-2009 01:19 PM
Last Post: Chrisso
  MegaSquirt and Direct Coil Control harkes 1 3,140 06-25-2009 06:19 PM
Last Post: harkes
  megasquirt wiring (stock distributor) shanemck 7 18,308 06-25-2009 12:30 PM
Last Post: BOOMEX
  problem whit megasquirt I v3 igniter wiring CIVER 2 6,393 12-15-2008 11:26 PM
Last Post: CHACAMAN
  4AGE MEGASQUIRT BASE MAP NEEDED shanemck 12 14,653 07-17-2008 08:03 PM
Last Post: shanemck
