Metal removal at rear, opinions
12-29-2012, 03:59 AM
Nice writeup, lots of good ideas
Did my pockets today, wont remove thin pisece behind bumper, but pockets are gone. Were in terrible condition, when removed i wighted them around 3,5kg (both). Nohachi, how much kg can be saved Daihatsu alternator ? Is it worth the hassle ? Thanks |
12-29-2012, 04:25 AM
Uzelac Wrote:Nice writeup, lots of good ideas 3.5kg is a huge amount of metal! Have you got pics of the final result? If looking at weight around the alternator, replacing the factory cast metal bracket with an alloy one would save a lot. |
12-29-2012, 04:29 AM
I haven't seen lightweight propshafts being mentioned here, surely that's something else to add to the list?
12-29-2012, 05:00 AM
Jezza_hr Wrote:I haven't seen lightweight propshafts being mentioned here, surely that's something else to add to the list? There is 2.6kg in savings in going from 2 piece to 2 piece (including the extra hardware needed to mount the 2 piece. I really dont think a carbon drive shaft will save much of anything to be honest. The single piece I think from memory was 5-6kg. |
12-29-2012, 06:44 AM
4000GT Wrote:Jezza_hr Wrote:I haven't seen lightweight propshafts being mentioned here, surely that's something else to add to the list? Forgot about that... If you thinking doing that go one piece! (Do you have adjustable link bars, to correct the pinion angle?) Use RX8 prop and adapt the ends to it, 100gbp for the prop and another 100 for the fabrication, cheap. ad you´re loosing rotating mass, lot more worth than just 2,6kg! One more thing, I recently changed from TRD blues and springs to a set of GAZ coilovers, definatly saved a few kg´s there as well! I hate to say but you´re in an expensive territory, were you need to consider everything. 2,6kg rotating mass is massive, and well worth the effort, but the prop ain´t as important as the clutch, cause its after the gearbox, do the clutch first! 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
12-29-2012, 07:51 AM
The weights I have seen in carbon driveshafts is 7kg, so heavier than the one piece drive shaft I have. Yes I have full adjustable rear arms, but an switching out to an S13 rear end soon.
The flywheel is a lightweight Excedy version. Not worried about the cost. I was going to hold off on changing the TRD suspension I have till I do the S13 rear end and go Tein in all likelihood. |
12-29-2012, 11:46 AM
4000GT Wrote:The weights I have seen in carbon driveshafts is 7kg, so heavier than the one piece drive shaft I have. Yes I have full adjustable rear arms, but an switching out to an S13 rear end soon. I know the S13 rearend is done and tested but you might want to have a look around other rearends as the S13 one is pretty heavy too although unsprung but I guess an FD one should be lighter if the size works out. AE86 ex-daily |
12-29-2012, 12:09 PM
Dicking around with the rear end is a lot easier to get wrong then it is to get right. I disagree that its done and tested. I haven't heard of any fast AE86s on the planet with the S13 rear end doing well in any kind of timed motorsport, but chime in if they exist.
Is a swap like that even allowed in class? How are you doing in class now? There is a lot of time in setup/tires/data anlysis and driver development. Whole seconds in stead of the tenths you'll find with further weight reduction. How far are you along that curve? Might be a better place to continue looking. A wheel to steer the front of the car A pedal to steer the rear |
12-29-2012, 12:35 PM
What about this?
Im sure that would lose alot of weight! |
12-29-2012, 12:38 PM
Part of the S13 conversion is to do with future development of the car, Ill likely do a 3UZ turbo or 7AGTE conversion in a couple of years, so the plan is finish the widebody, do the S13 front and rear suspension to get the offset right for some CR01 wheels and dunlop slicks. Ill be using all alloy arms etc so I think the rear end weight might not be that much over the live axle.
Power Steering Removal | 20valver | 2 | 824 |
4AGE cylinder head plug removal | Ivan141 | 5 | 2,093 |
Sill removal | totta Crolla | 3 | 1,987 |
09-14-2022 06:30 PM Last Post: totta Crolla |
Why Manual Steering Rack ?? Power Steering Removal | juantonwan | 26 | 43,427 |
Suspension Opinions - Please vote! | Bean | 32 | 31,035 |
09-11-2014 12:53 PM Last Post: Bean |
