Mikzu IV ae86 from Luxemburg+ shuttle + ke25 + 280z + chaser
10-21-2009, 09:32 PM
Post: #101
Inside! Without the airbox they were not as effective. They are the short type 30-35mm and actually gain kW across entire rev range. I'll post the dyno curves for you (this is std intake curve, will add Imec, just have to find...)
![]() ![]() ![]() ![]() He found running these back to back on dyno INSIDE factory airbox, netted an EXTRA 3kw below 4200rpm and an extra 6kw above 4900rpm!!! (with no air box it lost out quite a bit!) This mod was performed on a low km stock AE111 Levin. With fresh oil, new air filter, fuel filter, reset timing, netted 94kw, then fitted Imec ram tubes netted 100kw. ![]() RokuSteady : Shakotan - Tsuraichi - Hippari - Onikyan : 神奈川 様式 |
11-03-2009, 09:32 PM
Post: #102
Hmm Now I have both so I can compare soon...
The red one's one the photo above I allready tested on the road. Without airbox it is only fun above 7k. But the sound.... is like we should say in the Netherlands : GEIL ! Check: http://www.youtube.com/watch?v=H2tX-Sz8UxM Now I received this.......... ![]() ...........so that should be tested soon ![]() Unfortunately on the AE101 because someone stole the AE111 before I could buy it ..... ![]() Corolla AE101 Twincam 20v 6 speed LSD Levin BZ-G AE111 Twincam 20v 6 speed Starlet GT-Turbo |
11-03-2009, 09:47 PM
Post: #103
Kees Wrote:Hmm Now I have both so I can compare soon... wow, its really flying ![]() I just ordered a new engine from holland. the crank on the old one was scratched on the 4 conrod position, so the new bearings were gone in 30min. I will repair the old engine with better time... 280z '75 audi S4 B5 '99 KE25 '71 |
01-29-2010, 08:00 PM
Post: #104
ae111 finally fully road legal, I had to adapt corolla ae100 headlights to pass the luxembourgish Mot. and the engine works great...
the ae86 should be repainted in the near future. I received my 4agze harness from phoenix tuning but the car does not run. it starts very easily but shuts down after a few revolutions, like it would not use the main injectors, only the start injector... newest acquisition: Honda civic shuttle aka. wagon: 1,6 d16 4x4: soon itll be rocking some xxr 15x8" et0 and a lowering. all it needs ![]() ![]() ![]() ![]() 280z '75 audi S4 B5 '99 KE25 '71 |
01-29-2010, 08:55 PM
Post: #105
Kees Wrote:Hmm Now I have both so I can compare soon... I think you'll find the red ones will perform better INSIDE air-box on road car. If the aluminium velocity stacks are to suit AE101 throttle bodies - the diameter will need to be enlarged slightly (+3mm Ø) to match AE111. ![]() ![]() RokuSteady : Shakotan - Tsuraichi - Hippari - Onikyan : 神奈川 様式 |
01-29-2010, 10:10 PM
Post: #106
AHHH Your the guy who outbid me on that damn wagon!!! I want another one so bad. Here is the current one. 16x9 and 16x10 steffan evos with a supercharged CRX motor (not in yet). I have a brand new d16 with a turbo kit that was supposed to go in it until I bought the crx motor and supercharger. Awesome little cars.
01-30-2010, 12:43 PM
Post: #107
ragenasian Wrote:AHHH Your the guy who outbid me on that damn wagon!!! I want another one so bad. Here is the current one. 16x9 and 16x10 steffan evos with a supercharged CRX motor (not in yet). I have a brand new d16 with a turbo kit that was supposed to go in it until I bought the crx motor and supercharger. Awesome little cars. lol small world ![]() yeah I have been drooling on your wagon for quite some time and decided by accident to bid on this one on ebay ![]() for the ae111 I abandoned all modification plans for now, gotta concentrate on the ae86 and my wagon 280z '75 audi S4 B5 '99 KE25 '71 |
01-30-2010, 12:53 PM
Post: #108
I only wanted that one because it was only 30kms from my house and that I have so many parts for Hondas I could build a turbocharged version with full exhaust, and full Tein suspension. I will find another one soon enough.
01-30-2010, 02:37 PM
Post: #109
Mikzu IV Wrote:the ae86 should be repainted in the near future. I received my 4agze harness from phoenix tuning but the car does not run. it starts very easily but shuts down after a few revolutions, like it would not use the main injectors, only the start injector... hmm had a similar problem - http://www.aeu86.org/viewtopic/ae86/t/49...c/start=25 there's an additional ground wire for the injectors in the stock loom going onto the intakeplenum... without it the engine dies quickly after start... have you fitted the japspeed 4-2-1 plenum yet I'm interested if it clears the LHD steering column... BTW niice cars ![]() AE86 ex-daily |
02-04-2010, 02:59 PM
Post: #110
Bean Bandit Wrote:Mikzu IV Wrote:the ae86 should be repainted in the near future. I received my 4agze harness from phoenix tuning but the car does not run. it starts very easily but shuts down after a few revolutions, like it would not use the main injectors, only the start injector... yeah all the masses are connected to the ground, but I noticed that one of the coils is not receiving any signal from the igniter :/ so only 2 spark plugs are sparking. both coil packs and ignition leads are ok, I checked them by cross connecting... "igniter is also grounded" I was wondering that it must be my 7mgte igniter that I wired like told here: http://www.club4ag.com/faq_and_tech_page...%20DLI.htm any ideas? or has someone ever really done this 7mgte to 4agze ignitor conversion? and the japspeed collector did not work ![]() 280z '75 audi S4 B5 '99 KE25 '71 |
AE86+KE25 = KE86 | SAM | 17 | 21,308 |
12-07-2009 06:48 PM Last Post: projectrollas |
My 1972 KE25 Corolla Coupe | awex | 64 | 92,932 |
07-10-2009 12:02 AM Last Post: awex |
Mikzu's 4A-GZE project | Mikzu IV | 22 | 35,489 |
11-03-2008 04:11 PM Last Post: Jousi |
NoHachi's KE25 corolla coupe | Ivan141 | 206 | 172,602 |
12-13-2006 10:44 PM Last Post: robokill |
