Mounting 4agze
11-02-2005, 09:12 PM
Mounting 4agze
Hi all!
Are there any good ideas about wiring the 4agze in a hatchi? I have the original 4ag harness and the 4agze and both ecu's. Must I use the wires of the 4agze and also the junction blocks? Or can I combine the two harnesses together. |
11-03-2005, 02:31 AM
Mounting 4agze
That's a fucking hard task as far as i know...
thats the deal, tho, if you make that your fine. In my car, i have a custom wiring loom using the gZe harness and ECU. I ve heard in here for a guy in Netherlands that can convert the age ecu to fit the gZe harness. Something like that might cost more but ts gonna save you alot of trouble. Also you gotta keep in mind that: Its a CUSTOM job, so if you dont have a clue about it, more or less ONLY the guy that will do the job will be able to fix it... TALK TO YOU MORE IN A MORE RESONABLE HOUR danielvanderwoude Wrote:looks like the nmwisima joke saved you in the end ![]() |
11-03-2005, 09:09 AM
Mounting 4agze
The hard thing I guess is making the connections to the other wiring looms. You can probably hook up the GZE loom to the engine, but all the connectors that arent directly related to the engine will offcourse end up in completely the wrong place. You could extend the GZE loom and adapt it to look like the AE86 loom, or you could butcher the AE86 wiring and add what's needed for the GZE. Personally I would prefer to buy some new wires and adjust the GZE loom, that way you have something to fall back on if it should ever be necessary.
You could best wait for Ad's (turborolla) input on this though, he has lots of experience with this. FABRICA MI DIEM, PVNC! |
11-07-2005, 09:29 AM
Mounting 4agze
It's not too hard to do yourself.
- Get a good wiring diagram (Techdocs at http://www.toymods.org.au or through club4ag.com) - Strip the casing off all the looms - Work out what each wire is for and how much of the ZE loom you will need to use (It should be suprisingly little) - Cut the plugs you will need off the loom (leave a few inches of trailing wire) - Plug the plugs onto the engine - Mount your ECU somewhere nice - Run each wire from the back of the ECU to the plug on the engine (shorten the wire or add extra sections as needed) - Splice any body wiring needed (ignition power, AC switch, etc) into the loom - Start it up and enjoy that SC torque Yes it is a bit of a bitch of a job, but well worth it. If anything ever goes wrong you will know exactly how to fix it. And you can NEVER label enough things when you are pulling a loom apart. Hen No, this thing is totally stock standard officer... |
11-08-2005, 01:44 AM
Mounting 4agze
Indeed, it isn't that hard I think.
I found the following: http://www.mr2oc.com/showthread.php?t=63695 The molex connector is the most important one. But thanks for the tips Hen ![]() |
11-14-2005, 11:59 PM
Mounting 4agze
How can I get the engine failure codes?
Shorten to wires? |
11-15-2005, 12:21 AM
Mounting 4agze
Got already:
Check Engine light Sparks.... ![]() |
11-16-2005, 04:23 PM
Mounting 4agze
yes hen is right not hard but just systematic work through it slowly and lable everything! the diagrams on club4ag.com are sufficient
when i took apart the loom for my one there were several modules which were not anything to do with the engine at all! hopefully i will have a write up soon for you guys! as my 7age is rattleing! (too much supersaver engine oil) ![]() Run Free and take a Goodline V8FOURCAM32 MK3 Supra Patchwork AE86 from 4AGE to 7AGE to 4AGZE and now 4AGEU20v suzuki cappuccino mondeo TD |
11-16-2005, 08:53 PM
Mounting 4agze
Is it easier to prepare the wiring while the engine is out of the car or should it first be put in the car and then wired up?
Usually the engine is put in first I guess, but I think that all the wiring is easier accessible outside the car, am I right? also more room for soldering... |
11-16-2005, 09:00 PM
Mounting 4agze
I already put the engine in, connected the most of the wires.
Easiest thing is to mount the engine part of the wires before mounting. After installing the engine I put in the ecu. And then connecting the 22pins connector to the other relays/wires. I have almost the complete wiring of the 4agze equiped car ![]() |
Horn mounting... | Mylesmck | 6 | 2,141 |
07-12-2023 10:03 AM Last Post: Mylesmck |
Exhaust back box mounting | totta Crolla | 3 | 4,651 |
12-01-2010 07:44 PM Last Post: totta Crolla |
Engine mounting insulators | Sanity Clause | 5 | 6,189 |
03-30-2008 12:13 PM Last Post: Sanity Clause |
Levin rotating grills, mounting? | Juhler | 8 | 9,874 |
08-18-2007 02:59 PM Last Post: Juhler |
mounting rear wing on hatch | Aaron | 3 | 4,954 |
04-18-2007 04:22 AM Last Post: JonnyAE86 |
User(s) browsing this thread:
