My 86 dynoed 148 hp on wednesday 10 2013
07-12-2013, 01:23 PM
hello,
I have just dynoed my car to see how was my rebuilt and to set the timing of my camshaft.
That might interest someone.
the set up is: i paste my thread from 4AGE results
makkuro Wrote:
makkuro Wrote:What cam timing will you recommend formy set up?
264° hks in and ex
martelieus header 4-2-1 and complete muffler
trd head gasket 0.8mm, shave 0.5 mm
toda adjustable cams
brand new oil pump
seals (segments et tous les joint, not sure in english)
My 86 is a zenky model
Thanks
Now i know what timing i will use.
but first i want to thank Project D who guided me all the way through ( choice of the cams, choice of the size of the gasket, choice of the muffler, how much to shave, how to break in the engine etc to get the number that i got. Thumbs up!
He convinced me to keep my engine and upgrade it as it is now instead of doing a swap where i will spend way more because you never know how is the health of the engine, real mileage, change the wires.etc. you know what i mean.
thanks dude!
here is my number: 148hp on not ultimate condition
[Image: AEU86 AE86 - My 86 dynoed 148 hp on wednesday 10 2013]
Also project d
Quote:If I can add few things up about makkuro's setup.
The engine head, apart from the parts mentioned earlier, is absolutely stock. (Not ported)
Also, he still use the stock ECU
1st: 148hp (135rwhp) @ 7327rpm and 158Nm (116.6ft-lbs) @ 5294rpm
2nd: 146.2hp (133rwhp) @ 6868rpm and 163.3Nm (120.5ft-lbs) @ 5308rpm
3rd: 147.4hp (134rwhp) @ 7059rpm and 162Nm (119.5ft-lbs) @ 5191rpm
my toyota is fantastic
07-14-2013, 12:52 AM
Thumbs up!
Dan -
07-31-2013, 01:01 PM
What percentage of transmission loss do you boys get through your prop?
07-31-2013, 03:10 PM
Alex170984 Wrote:What percentage of transmission loss do you boys get through your prop?
9%
07-31-2013, 04:52 PM
How is that possible, when the MR2 is rated at around 15% and the engine is pretty much over the rear wheels Huh
07-31-2013, 05:26 PM
That does sound very conservative for an FR car. None the less.. 135 at the wheels is nothing to sneeze at.
07-31-2013, 06:10 PM
9%
hmmmm... this is an age old problem... there is no set figure to RELIABLY determine whp from hp.
please read(English).... http://www.modified.com/tech/modp-1005-d...index.html
As a basic rule (drivetrain loss)... longitudinal USUALLY use 15%-20%, transverse USUALLY use 10%-15%, and finally awd USUALLY 20%-30%
Dan -
08-09-2013, 10:04 AM
i got this number when i asked the person who operated the dyno.
08-09-2013, 11:14 AM
Isn't the Transmission loss is calculated when the dynoguys accelerate and let off (many time) before the real WOT pull? :roll:
SR Team
BURN THE RUBER NOT YOUR SOUL!
