My Friend's Projects Started.
12-23-2009, 07:34 PM
Post: #51
Parts renewal time
![]() ![]() We start with engine heater ![]() ![]() ![]() Body would unscrew. ![]() ![]() To remove the engine before removing the propeller are. ![]() After removing the five screws that are ![]() Bottom we have already removed all the parts ![]() Top row came to disassemble ![]() ![]() ![]() |
12-23-2009, 07:50 PM
Post: #52
Heating from inside the engine shit
![]() Plastic parts are destroyed ![]() ![]() time to pass free of metal parts ![]() During primer and paint ![]() ![]() Parts assembly time! Fan motors are starting to collect, coils, and then we sat down, ready to be attached to the body are.. ![]() Second stage of the window and window installation is complete ![]() Now at the top, window mechanism, electric installations, metal tray and finish the installation done ![]() |
12-23-2009, 07:52 PM
Post: #53
12-23-2009, 09:23 PM
Post: #54
12-24-2009, 05:01 PM
Post: #55
Nice work!
![]() 1985 AE86 (ハチロク) Levin - Summer time daily driver |
12-24-2009, 08:42 PM
Post: #56
Thanks my firends,radiator fan is on the menu today
![]() Not saying more dirt ![]() Screws and clips are removed ![]() To remove the radiator fan of the types and status could come after mug deplorable and anywhere in the leaked previously been treated in ![]() Upper body at the bottom are dedicating so much shit we saw really stood in the stomach if you are doing ![]() The windows will be removed in the foam have survived already pas ![]() |
12-24-2009, 08:48 PM
Post: #57
To remove the windows are removed first arm
![]() ![]() Washing polishing by sanding triple hi ![]() ![]() the consistency of most shiny as pure can come back to life when you're happy ![]() Primers at a more hair to prevent corrosion of metals are ![]() paint time ![]() |
12-24-2009, 09:00 PM
Post: #58
we do not like the first clear mastery of the painter a painter to deal with, we resumed operations room
![]() ![]() ![]() Completed our radiator replace worn-out life is our custom radiator is sparkling new ![]() Instead we tried to install a new radiator but did not enter because of corners ![]() ![]() would dive with Monster ![]() ![]() enters instead of the end well done ![]() ![]() We are where we paint finishes by making stone ![]() Came to the sponges during the renewal process. 0.8 to 1.0 for windows milimi other places I decided to use a sponge milimi research is needed after a long bonding with the best results took derby ![]() Sponge start working from our acid baths rusty metal we send a lot. ![]() foam coating process, and we finish late ![]() |
12-24-2009, 09:05 PM
Post: #59
We start with our assembly, our wheels into place and then, and radiator caps are finished installing the main
![]() Provides the movement of arms and cover wire tension with this part of the plug and we finish our job. ![]() The top, and we renewed our sponges are finished. ![]() Rusted metal out of our acid bath after the scan with wire brush are ready for paint. Dirt and rust from metal-free and our fans, our radiators. ![]() |
12-27-2009, 06:14 PM
Post: #60
Nice work man
![]() Toyota Sprinter Trueno 4AG Engine... |
ZaX's new projects | ZaX | 6 | 3,036 |
01-21-2023 07:23 PM Last Post: ZaX |
ZDoman's projects - Hungary | ZDoman | 185 | 184,230 |
10-14-2015 06:27 PM Last Post: BOOMEX |
My Project has started... | Rasteirinho | 195 | 208,126 |
02-08-2015 05:35 PM Last Post: Rasteirinho |
Foto from ROTACHI projects 2009 | jardapek | 3 | 5,934 |
11-17-2008 11:02 PM Last Post: jardapek |
Projects section rules | banpei | 2 | 38,732 |
02-18-2005 11:24 AM Last Post: banpei |
