My Friend's Projects Started.
12-23-2009, 07:34 PM
Post: #51
Parts renewal time Smile
[Image: AEU86 AE86 - My Friend's Projects Started.]
We start with engine heaterHurray!
Body would unscrew.
To remove the engine before removing the propeller are.
After removing the five screws that are
Bottom we have already removed all the parts
Top row came to disassemble
12-23-2009, 07:50 PM
Post: #52
Heating from inside the engine shit
Plastic parts are destroyed
time to pass free of metal parts
During primer and paint
Parts assembly time!
Fan motors are starting to collect, coils, and then we sat down, ready to be attached to the body are..
Second stage of the window and window installation is complete
Now at the top, window mechanism, electric installations, metal tray and finish the installation done
12-23-2009, 07:52 PM
Post: #53
12-23-2009, 09:23 PM
Post: #54
Thumbs up! nice, nice! Thumbs up! i wonder if i can do the same with mine.
12-24-2009, 05:01 PM
Post: #55
Nice work! Thumbs up!
12-24-2009, 08:42 PM
Post: #56
Thanks my firends,radiator fan is on the menu todaySmile
Not saying more dirt
Screws and clips are removed
To remove the radiator fan of the types and status could come after mug deplorable and anywhere in the leaked previously been treated in
Upper body at the bottom are dedicating so much shit we saw really stood in the stomach if you are doing
The windows will be removed in the foam have survived already pas
12-24-2009, 08:48 PM
Post: #57
To remove the windows are removed first arm
Washing polishing by sanding triple hiSmile
the consistency of most shiny as pure can come back to life when you're happy
Primers at a more hair to prevent corrosion of metals are
paint time
12-24-2009, 09:00 PM
Post: #58
we do not like the first clear mastery of the painter a painter to deal with, we resumed operations room
Completed our radiator replace worn-out life is our custom radiator is sparkling new
Instead we tried to install a new radiator but did not enter because of corners Banging head
would dive with Monster Huh
enters instead of the end well done Thumbs up!
We are where we paint finishes by making stone
Came to the sponges during the renewal process. 0.8 to 1.0 for windows milimi other places I decided to use a sponge milimi research is needed after a long bonding with the best results took derby
Sponge start working from our acid baths rusty metal we send a lot.
foam coating process, and we finish late
12-24-2009, 09:05 PM
Post: #59
We start with our assembly, our wheels into place and then, and radiator caps are finished installing the main
Provides the movement of arms and cover wire tension with this part of the plug and we finish our job.
The top, and we renewed our sponges are finished.
Rusted metal out of our acid bath after the scan with wire brush are ready for paint. Dirt and rust from metal-free and our fans, our radiators.
12-27-2009, 06:14 PM
Post: #60
Nice work man Tongue
Toyota Sprinter Trueno 4AG Engine...
  ZaX's new projects ZaX 6 2,757 01-21-2023 07:23 PM
  ZDoman's projects - Hungary ZDoman 185 179,723 10-14-2015 06:27 PM
Last Post: BOOMEX
  My Project has started... Rasteirinho 195 200,787 02-08-2015 05:35 PM
Last Post: Rasteirinho
  Foto from ROTACHI projects 2009 jardapek 3 5,768 11-17-2008 11:02 PM
Last Post: jardapek
  Projects section rules banpei 2 38,489 02-18-2005 11:24 AM
