Thread Closed
My Red Panda :)
12-19-2005, 09:39 AM
My Red Panda :)
Man, there is some bloke sitting in your car on this picture Huh
http://oldskull.sytes.net/hachi/DSC03897.JPG
Nice garage btw. Smile
12-19-2005, 06:23 PM
My Red Panda :)
@banpei: Thanks for your offer but its solved. Today I visit friend of friend of mine. My friend told me his friend know lot of car electrical. So I can give him a try. So my plan B is to ask you if he can't. But he fixed up. I am so happy with it Smile I just need to find black interior for those cd player. Mine look so bad.
@ae82_gt: Yeah this need to clean up soon, I need some advis to clean up because I dont know what I need to use to clean them up.
Yeah Ivan is right, the owner bring the car from Swirtzerland to Netherland about 8 years ago.
@James: Yeah I will come back to the last owner in January, seem I have 3 months garanty so he will do some check up. So I will ask him to replace those oil. He did replace them before I bought it, so in January should be ok to replace new one.
@ZaX: The bloke are the new owner of the car now Tongue Hurray! Hurray! He should take the care the car very well Smile
Yeah I must say the garage are very nice and big. I wish I have those too. Tongue Huh
12-19-2005, 09:07 PM
My Red Panda :)
oldskull Wrote:@banpei: Thanks for your offer but its solved. Today I visit friend of friend of mine. My friend told me his friend know lot of car electrical. So I can give him a try. So my plan B is to ask you if he can't. But he fixed up. I am so happy with it Smile I just need to find black interior for those cd player. Mine look so bad.
Small hint: I used an Mitsubishi (1996+) ISO harness and remodelled it to a toyota according to this link:
http://www.dorikaze.ca/dorikaze_guides_d...php?a_id=2
This is the pin-layout:
[code:1]
1983 to 1986 Wiring Harness:
Pin What It Does Colour In Dash New Harness Match
1 Right Front Speaker (+) Green Gray
2 Left Front Speaker (+) Pink White
3 Right Front Speaker (-) Blue Gray w/ Black Stripe
4 Left Front Speaker (-) Purple White w/ Black Stripe
5 Ground Wire Black Black
6 +12 Volt Ign Wire Gray Red
7 Power Antenna Wire 1 Blue (join wires 1 &2 together
8 Power Antenna Wire 2 to this blue wire)
9 Do Not Use
10 Right Rear Speaker (+) Red Purple
11 Right Rear Speaker (-) White Purple w/ Black Stripe
12 +12 Volt Battery Wire Blue w/ Yellow Stripe Yellow
13 Left Rear Speaker (+) Black Green
14 Left Rear Speaker (-) Yellow Green w/ Black Stripe
[/code:1]
Then you can place any ISO-connector compatible radio in your hachi. Smile
[Image: AEU86 AE86 - My Red Panda :)]
12-19-2005, 09:56 PM
My Red Panda :)
Hey thanks for those layout. I am planning to put ISO-connector when I bought new cd player. So I can use this!! thanks again banpei
banpei Wrote:Small hint: I used an Mitsubishi (1996+) ISO harness and remodelled it to a toyota according to this link:
[code:1]
9 Do Not Use
[/code:1]
12-20-2005, 12:01 AM
My Red Panda :)
oldskull Wrote:Hey thanks for those layout. I am planning to put ISO-connector when I bought new cd player. So I can use this!! thanks again banpei
I've done mine a few months ago and know how much pain it is to find the correct data. Wink
I asked at three dealers if they knew anything, visited various car-parts shops and searched the internet and still found nothing. Undecided
Lucky enough I found the mitsubishi connector looking familiar. Hurray!
I also found the mitsubishi pin-layout, it's the second one. Unfortunately only in pdf. Undecided
12-20-2005, 06:30 PM
My Red Panda :)
Thanks again banpei.
Someone here in Holland got pair of wiper in good condition for sale? Smile
There is old stickers on my back and front window. I would like to remove them, any suggestion to remove them without damage the glass?
thanks
12-20-2005, 07:26 PM
My Red Panda :)
Quote:Someone here in Holland got pair of wiper in good condition for sale?
You can order them new Smile
12-20-2005, 07:33 PM
My Red Panda :)
oldskull,
like ae82_gt mentioned, just go to your local toyota dealer and ask them to order them for you. They dont cost much more then the wipers you can get at hallfords or whatever.
Does anyone have part numbers for these? I need some aswellSmile
as for the stickers, heat them up with a blowdryer or something. Be carefull with this but the stickers should let go pretty easily when warmed up.
12-20-2005, 08:34 PM
My Red Panda :)
ah ok, I will get them from toyota dealer around here, oh yeah maybe someone got part number? darn i dont have any hairdryer Sad Tongue i should get them soon Smile
today the engin timing seems to be bit beter, cold about 2000rpm and warm about 1200rpm. but still strange when i press clutch pedal (koppeling) the timing up very fast. when I lose it and it drop back.
anyway I hope this will solve soon.
12-20-2005, 09:37 PM
My Red Panda :)
Partnrs;
Blade lh 85220-14390
Blade rh 85220-16280
arm lh 85210-12180
arm rh 85210-12610
Let your dealer check them because there can be a number change
Thread Closed
