My little (not really...) project - Soon to be all done?!?
05-12-2011, 08:22 AM
Post: #471
Just a guess when I look at your dyno curve, is you VVT acting as it should?
Had 2 blacktops before I came back to the 16V. Both only made 150-155 hp at the crank. was disappointed to!
http://monkeymagic86.wordpress.com
05-12-2011, 01:14 PM
Post: #472
Yes the VVT is working ok. We fiddled a bit with it on the dyno Smile
[Image: AEU86 AE86 - My little (not really...) p...ll done?!?]
05-14-2011, 06:09 PM
Post: #473
Man the combination for your car is great- rims, paint, engine and all the care Respect!
05-14-2011, 10:10 PM
Post: #474
Thanks Smile
05-22-2011, 11:27 PM
Post: #475
Mine made 157 HP / 167Nm @ flywheel (also stock). I didn't expect anything better than that. Toyota lies Tongue Your engine is fine I think. Maybe it just needs a little tweak here and there.
05-22-2011, 11:52 PM
Post: #476
My hachi 20V ST produces 155 bhp on the rear wheels and 147Nm of tourque. Still needs some fiddling with to get it all to run smoothly.
Also, if you did have some close ups of the intake box, that would be awesome!! Thumbs up!
05-25-2011, 01:49 PM
Post: #477
Well I know that the dyno is rather conservative so its properbly around the same as most stock 20Vs. But you allways hope for a bit more Smile
11-22-2011, 06:56 PM
Post: #478
And back from the dead: A couple of friends and I just bought a Lexus IS/RS200 AZ6 gearbox each to fix the ratio isues of the T50.
The plan for now is to make an adaptor plate to fit between engine and gearbox or weld the T50 bellhouse to the AZ. The Leen kit looks great but is just way to expensive...
11-24-2011, 11:34 AM
Post: #479
That's a good upgrade... I'm thinking in the same option to my car... Keep us posted about the progress...
Keeping the AE86 alive!
11-24-2011, 04:01 PM
Post: #480
Great keep us updated on the box.
And the dyno is not bad either, i would scream from luck to have 167Nm from 1600cc,
Not the th 145Nm i have now.
Bentley how are the specs? Silvertop should have similar torque to the Bt.
http://www.86ers.org
  Ivan's coupe: bodywork is done Ivan141 676 802,723 08-07-2024 08:46 AM
  (Catching up...) OST-082: Nope, never again... at least not without all the parts oldeskewltoy 0 1,560 06-28-2022 09:17 PM
  OST-066: I get all wavy (4AC content) oldeskewltoy 10 14,373 04-03-2020 04:29 PM
Last Post: Power_uP
  d3nso's little AE86 N2 build d3nso 27 34,892 11-13-2017 11:42 AM
  Doc's KE20: - really coming together now The Doctor 548 521,311 08-03-2011 11:57 AM
Last Post: The Doctor
