My little (not really...) project - Soon to be all done?!?
06-19-2012, 07:48 PM
Post: #491
It seems that the input shaft will be too short and the splines won't reach the clutch...
Sarcasme is just one of the things I offer Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch |
06-20-2012, 06:11 AM
Post: #492
you'll need to get off some mm at the front and at the rear of the BH to match the thick of the plate
SR Team BURN THE RUBER NOT YOUR SOUL! |
06-20-2012, 04:13 PM
Post: #493
BOOMEX Wrote:you'll need to get off some mm at the front and at the rear of the BH to match the thick of the plateThe shaft it selfe is 5 mm shorter than on the T50. and you kan mil off 5 mm at most at the front of the AZ6 and none at the rear as it houses the front bearings. It is possible on a RS200 / 3SGE AZ6. The bell house barely fits the tunnel but its possible. My friend Martin just finished this swap :wink: Sarcasme is just one of the things I offer Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch |
06-20-2012, 05:43 PM
Post: #494
or just do extension to crank bearing. OR some friends have put wider bearing just and its fit.
06-24-2012, 10:17 AM
Post: #495
Cutting the 10 mm plate was a bitch:
Now we just need to have the parts welded: To do: Welding Finding a clutch cylinder that will fit Custom cross member Custom drive shaft Speedo drive Mounting AZ6 Beat the h*** out of it Sarcasme is just one of the things I offer Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch |
06-24-2012, 11:32 AM
Post: #496
How are you going to get the the shaft and the engine axed?
06-24-2012, 12:53 PM
Post: #497
We made a fixture that bolts to the T50 BH with a hole for the shaft.
06-24-2012, 01:25 PM
Post: #498
Jan Pedersen Wrote:We made a fixture that bolts to the T50 BH with a hole for the shaft. Cool. I'm thinking about doing the same thing SR Team BURN THE RUBER NOT YOUR SOUL! |
07-02-2012, 06:27 PM
Post: #499
AZ6 for 4AGE:
Speedo drive from a W5x: T50 clutch fork: Shifter relocation part I: Still needs some welding and a bracket for the T50 shifter... And its finally mounted: It just fits with lower engine mounts Sarcasme is just one of the things I offer Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch |
07-02-2012, 06:30 PM
Post: #500
BOOMEX Wrote:Do it! Its awesomeJan Pedersen Wrote:We made a fixture that bolts to the T50 BH with a hole for the shaft. Sarcasme is just one of the things I offer Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch |
Ivan's coupe: bodywork is done | Ivan141 | 676 | 796,468 |
08-07-2024 08:46 AM Last Post: banpei |
(Catching up...) OST-082: Nope, never again... at least not without all the parts | oldeskewltoy | 0 | 1,529 |
OST-066: I get all wavy (4AC content) | oldeskewltoy | 10 | 14,011 |
04-03-2020 04:29 PM Last Post: Power_uP |
d3nso's little AE86 N2 build | d3nso | 27 | 34,660 |
11-13-2017 11:42 AM Last Post: mad.matt |
Doc's KE20: - really coming together now | The Doctor | 548 | 518,031 |
08-03-2011 11:57 AM Last Post: The Doctor |
User(s) browsing this thread: 45 Guest(s)
