My little (not really...) project - Soon to be all done?!?
06-19-2012, 07:48 PM
Post: #491
It seems that the input shaft will be too short and the splines won't reach the clutch...
[Image: AEU86 AE86 - My little (not really...) p...ll done?!?]
06-20-2012, 06:11 AM
Post: #492
you'll need to get off some mm at the front and at the rear of the BH to match the thick of the plate
SR Team
BURN THE RUBER NOT YOUR SOUL!
06-20-2012, 04:13 PM
Post: #493
BOOMEX Wrote:you'll need to get off some mm at the front and at the rear of the BH to match the thick of the plate
The shaft it selfe is 5 mm shorter than on the T50. and you kan mil off 5 mm at most at the front of the AZ6 and none at the rear as it houses the front bearings.
It is possible on a RS200 / 3SGE AZ6. The bell house barely fits the tunnel but its possible. My friend Martin just finished this swap :wink:
06-20-2012, 05:43 PM
Post: #494
or just do extension to crank bearing. OR some friends have put wider bearing just and its fit.
06-24-2012, 10:17 AM
Post: #495
Cutting the 10 mm plate was a bitch:
Now we just need to have the parts welded:
To do:
Welding
Finding a clutch cylinder that will fit
Custom cross member
Custom drive shaft
Speedo drive
Mounting AZ6
Beat the h*** out of it Big Grin
06-24-2012, 11:32 AM
Post: #496
How are you going to get the the shaft and the engine axed?
SR Team
06-24-2012, 12:53 PM
Post: #497
We made a fixture that bolts to the T50 BH with a hole for the shaft.
06-24-2012, 01:25 PM
Post: #498
Jan Pedersen Wrote:We made a fixture that bolts to the T50 BH with a hole for the shaft.
Cool. Thumbs up!
I'm thinking about doing the same thing Wink
SR Team
07-02-2012, 06:27 PM
Post: #499
AZ6 for 4AGE:
Speedo drive from a W5x:
T50 clutch fork:
Shifter relocation part I:
Still needs some welding and a bracket for the T50 shifter...
And its finally mounted:
It just fits with lower engine mounts Hurray!
07-02-2012, 06:30 PM
Post: #500
Cool. Thumbs up!
Do it! Its awesome Hurray!
  Ivan's coupe: bodywork is done Ivan141 676 808,682 08-07-2024 08:46 AM
  (Catching up...) OST-082: Nope, never again... at least not without all the parts oldeskewltoy 0 1,584 06-28-2022 09:17 PM
Last Post: oldeskewltoy
  OST-066: I get all wavy (4AC content) oldeskewltoy 10 14,756 04-03-2020 04:29 PM
Last Post: Power_uP
  d3nso's little AE86 N2 build d3nso 27 35,054 11-13-2017 11:42 AM
  Doc's KE20: - really coming together now The Doctor 548 525,410 08-03-2011 11:57 AM
Last Post: The Doctor
