NA Build Questions | Blue-/ Redtop questions
02-16-2013, 04:00 AM
Bean Bandit Wrote:my recommendation is get the car first and do some driving - in most cases there are other more crucial areas to fix/modify before you need to spend money on the engine Agree, my little rebuild 4AGE bluetop on stock cams with a bit head work on stock ecu makes 121 whp (140 engine hp) That with a set of mild 264 cams should make 150hp easy on stock Ecu. Your shopping list, with a set of pistons and a proper exhaust, and decent cams (272, 8,5mm), sounds more like >160 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
Messages In This Thread |
NA Build Questions | Blue-/ Redtop questions - d3nso - 02-15-2013, 03:52 PM
[] - Jan Pedersen - 02-15-2013, 05:46 PM
[] - oldeskewltoy - 02-15-2013, 08:40 PM
[] - Jan Pedersen - 02-15-2013, 10:15 PM
[] - fax0815 - 02-16-2013 04:00 AM
Re: NA Build Questions | Blue-/ Redtop questions - robokill - 02-16-2013, 12:02 PM
[] - oldeskewltoy - 02-25-2013, 12:31 AM
[] - oldeskewltoy - 02-25-2013, 07:01 PM
7AGE Build | apardal | 5 | 710 |
08-02-2024 12:11 PM Last Post: apardal |
Build your own adjustable fuel pressure regulator ;) | oldeskewltoy | 8 | 20,803 |
4age blue top from MR2 same intake manifold? | dinkers542 | 8 | 10,291 |
11-02-2014 05:24 PM Last Post: ditn |
My 4AGE N/A build | Lewy | 17 | 19,509 |
01-25-2013 04:42 PM Last Post: Lewy |
what bearings for my build? | Bean | 6 | 6,333 |
09-22-2012 10:25 PM Last Post: oldeskewltoy |
