Need engine,any engine
10-26-2006, 01:17 AM
What other engine would fit the t50 and engine mounts. In other words is there any other engine that i could just slap into hachi plug&play style? doesnt matter what engine..
and does anybody have a working 4a-g near slovenia to sell?
10-26-2006, 08:14 AM
a 3A will fit... so will 4A-C
don't have one to sell, sorry.
get a 4A-FE and use your AG head.
[Image: AEU86 AE86 - Need engine,any engine]
Koukis - Red, Silver/Gray,
10-26-2006, 08:30 AM
1. In some posts ago I saw that in NL there are good 4age from junkyard for 200-300 eur. You can make some calls to transport agencies and arrange the transport. What about the transport by train?
2. Contact robotype ( he is from Milano, Italy ). As far as I know he had a working 4age redtop from corolla ae92 a year ago. He might still have it...
Regards
Andrej
10-26-2006, 08:45 AM
I might cancel my smallport project due to financial reasons. If you buy my smallport you could have 140-150HP easily andit's not very far from you, in Budapest.
Smallport intake adapter has to be converted to the RWD style but I can help you to do this. More in private.
10-26-2006, 09:52 AM
the smallport is the latter (ae92) no tvis version right? will my bluetop manifold fit?
in what cars ca i find 3a and 4ac engines? wasnt it said that 4af block is a lot less rigid than the 4ag?
what about the engine mounts? can i use my engine mounts?
the point is i would like to have a working engine, that i can just service it (oil, filters) and run it.
10-26-2006, 09:58 AM
The smallport has smaller intake ports (how strange Smile) than the bluetop bigport. So your manifold won't fit.
Don't forget that almost every engine needs some modification since these newer engines were built mostly in FWD cars. So the smallport and the 4A-FE too.
Maybe my smallport is not what you need because it needs some things to work in your car.
10-26-2006, 10:05 AM
well i need a working bottom end. good bloock, rings, crank, bearings, oilpump.. i can use my head..
10-26-2006, 10:08 AM
Any A-series engine.
2A (1.3), 3A (1.5), 4A (1.6), 7A (1.Cool
10-26-2006, 10:13 AM
what work do i need to do, when converting to fwd type engines? can i use my mounts plug and play? is the T50 bolt-on for fwd engines?
10-26-2006, 10:14 AM
Apolan Wrote:what work do i need to do, when converting to fwd type engines? can i use my mounts plug and play?
Intake/exhaust rework.
  Squeaky seats - any tips? decryphe 2 1,601 10-18-2023 10:13 PM
Last Post: Power_uP
  D2 Coilovers any good? heshan 18 28,331 04-04-2017 02:40 AM
Last Post: hachirokkos
  Is this oil pump any good? megabob 3 5,516 02-08-2014 12:46 AM
Last Post: megabob
  All I should know about suspension before any modification damusto 20 23,677 05-24-2013 09:28 PM
Last Post: damusto
  Godspeed swaybars, any good ? Komba 5 6,644 05-05-2013 03:52 PM
Last Post: Komba
