Need engine,any engine
10-26-2006, 01:17 AM
What other engine would fit the t50 and engine mounts. In other words is there any other engine that i could just slap into hachi plug&play style? doesnt matter what engine..
and does anybody have a working 4a-g near slovenia to sell? |
10-26-2006, 08:14 AM
a 3A will fit... so will 4A-C
don't have one to sell, sorry. get a 4A-FE and use your AG head. ![]() Always remember: Rev it till it blows, then back off a bit... Zenkis - Orange, Red/Black, Silver/Black, Maroon/Blue Koukis - Red, Silver/Gray, |
10-26-2006, 08:30 AM
1. In some posts ago I saw that in NL there are good 4age from junkyard for 200-300 eur. You can make some calls to transport agencies and arrange the transport. What about the transport by train?
2. Contact robotype ( he is from Milano, Italy ). As far as I know he had a working 4age redtop from corolla ae92 a year ago. He might still have it... Regards Andrej |
10-26-2006, 08:45 AM
I might cancel my smallport project due to financial reasons. If you buy my smallport you could have 140-150HP easily andit's not very far from you, in Budapest.
Smallport intake adapter has to be converted to the RWD style but I can help you to do this. More in private. |
10-26-2006, 09:52 AM
the smallport is the latter (ae92) no tvis version right? will my bluetop manifold fit?
in what cars ca i find 3a and 4ac engines? wasnt it said that 4af block is a lot less rigid than the 4ag? what about the engine mounts? can i use my engine mounts? the point is i would like to have a working engine, that i can just service it (oil, filters) and run it. |
10-26-2006, 09:58 AM
The smallport has smaller intake ports (how strange
![]() Don't forget that almost every engine needs some modification since these newer engines were built mostly in FWD cars. So the smallport and the 4A-FE too. Maybe my smallport is not what you need because it needs some things to work in your car. |
10-26-2006, 10:05 AM
well i need a working bottom end. good bloock, rings, crank, bearings, oilpump.. i can use my head..
10-26-2006, 10:08 AM
Any A-series engine.
2A (1.3), 3A (1.5), 4A (1.6), 7A (1. ![]() |
10-26-2006, 10:13 AM
what work do i need to do, when converting to fwd type engines? can i use my mounts plug and play? is the T50 bolt-on for fwd engines?
10-26-2006, 10:14 AM
Apolan Wrote:what work do i need to do, when converting to fwd type engines? can i use my mounts plug and play? Intake/exhaust rework. |
Squeaky seats - any tips? | decryphe | 2 | 1,184 |
10-18-2023 10:13 PM Last Post: Power_uP |
D2 Coilovers any good? | heshan | 18 | 26,749 |
Is this oil pump any good? | megabob | 3 | 5,242 |
02-08-2014 12:46 AM Last Post: megabob |
All I should know about suspension before any modification | damusto | 20 | 22,099 |
Godspeed swaybars, any good ? | Komba | 5 | 6,339 |
05-05-2013 03:52 PM Last Post: Komba |
