Need info: Silvia S12
10-18-2008, 02:33 AM
Need some quick info, what do we have on the S12?
Engine 1.8 DET? Same as S13? LSD? Its a US market car i m talking about. Cheers, A. danielvanderwoude Wrote:looks like the nmwisima joke saved you in the endhttp://www.jdmbits.com |
10-18-2008, 08:42 AM
Hey nmwisima,
1.8 SOHC turbo, totally different engine from the one in the S13. Don't know about LSD though. Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
10-18-2008, 10:10 AM
No LSD, CA18et. Single cam 1.8 turbo. 140 bhp, shitty suspension, great look.
I reject your reality and substitute my own! No more Panda.. Tricolor bastard! If it 'aint broke, fix it 'til it is |
10-18-2008, 11:31 AM
This particullar car has a DET. It has catalytic converter and its Turbo. Has 173 PS. Maybe uses a newer engine?
Can someone use on an S12 parts from earlier Silvias??? danielvanderwoude Wrote:looks like the nmwisima joke saved you in the endhttp://www.jdmbits.com |
10-18-2008, 11:39 AM
the DET went in the S13 so i think thats the newer engine, yeah.
173 bhp in a S12 has to be big fun! The S12 is know as hard to modify, especially with the suspension.. I reject your reality and substitute my own! No more Panda.. Tricolor bastard! If it 'aint broke, fix it 'til it is |
10-18-2008, 04:57 PM
Megan reacing sells a coiloverset for the s12.
front can be done with some s13/s14 parts, rear can be done with corvette shocks iirc. |
10-18-2008, 10:06 PM
Thing is that Driftworks if full of S13-14-15 parts.
Engine ok. But LSD and brakes? danielvanderwoude Wrote:looks like the nmwisima joke saved you in the endhttp://www.jdmbits.com |
10-18-2008, 10:17 PM
AFAIK the 2.0 had LSD, but dunno about the 1.8...
I would go for the 2.0 which has a FJ20E, which can easily be swapped for the FJ20ET (Skyline R30 RS-X Turbo ), so IMO that's the better option. > (in Japan they actually delivered them to the Silvia!! ) BTW: according to Wikipedia the later versions did feature the CA18DET: http://en.wikipedia.org/wiki/Nissan_Silvia 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
10-18-2008, 10:20 PM
S13 diff should fit, open diff style
S14 diff is the same on the outside.. but viscous lsd on the inside, and another backhousing. (S14 diff with S13 diff backhousing will fit S13) S15 (Spec R) diff is also the same on the outside (Different backhousing again) And torsen. (S15 diff with S13 diff backhousing will fit S13) S13 should fit S12 with minor or no adjustments Rokuichi Power !! _________________________________________ Toyota Starlet KP61 2.0 vtec |
10-18-2008, 11:37 PM
Need info: Silvia S12 | |||
Toda timing info - with good general 4AG timing info too | oldeskewltoy | 0 | 4,275 |
Injector sizes info | ZaX | 19 | 36,048 |
frame/chassis rails info | Tig | 14 | 21,302 |
12-22-2012 10:38 PM Last Post: Tig |
Collecting info for w58 conversion | ditn | 1 | 4,815 |
06-01-2012 08:59 PM Last Post: ditn |
OER sk-itb set info | corolla4agze | 4 | 5,100 |
04-08-2012 10:56 PM Last Post: corolla4agze |
