(New) Rear Brake Disc Width
07-06-2010, 04:26 PM
I have been searching all over the net for this with no luck... Does anyone know the figure?
Thanks! SFD |
07-06-2010, 08:04 PM
i will messure mine tomorow or day after...
they have ess then 100km so like new... |
07-06-2010, 08:06 PM
iirc it's 10mm
EDIT: just checked the manual front is 18mm (17mm minimum) and rear is 10mm (9mm minimum) You can find the manual on the frontpage in the Technical section (left lower side) helps a lot for things like that and more. AE86 ex-daily |
07-06-2010, 09:56 PM
Thanks! Stupid me, didn't occur to look at the most obvious place!
I guess for 0.4mm it won't be a problem to fit a wilwood dynapro-2pot in the rear (says disc max width 9.6mm) I don't suppose anyone in the forum has done a similar modification? SFD |
07-06-2010, 10:04 PM
not done that modification but in worst case you will need to skim down the pad slightly if you can't fit the caliper over the disc
AE86 ex-daily |
Axle width | totta Crolla | 1 | 1,052 |
Switching diffs for disc brakes? | trippin | 6 | 2,622 |
07-08-2022 03:35 AM Last Post: trippin |
Rim width. Which is best.... | Dino86 | 5 | 6,708 |
Rebuild rear disc brakes toyota crown ms112 axle | bozu | 0 | 3,771 |
wider rear axle,track width,suspension questions | ditn | 6 | 8,632 |
