New in RWD, TE71 owner
01-27-2009, 06:12 PM
Ok so the engine is a 2C diesel, 2l
I have to check the gearbox. I went to a scrapyard and they have a 2l 3SFE. They tell me it comes from a MR2, but from what i found on the net, it did not. It could fit ? What kind of modification ? Thanks |
01-28-2009, 09:52 PM
3SFE would most probably fit the gearbox, but probably not the crossmember. But adapting the crossmember should not be your biggest problem I guess... Changing over a modern engine require a lot of electronics and looms to be implemented.
The 3SFE is AFAIK not MR2 but rather Carina II and lower spec Celicas. The MR2 MK1 has the 4AGE/4AGZE, MR2 the 3SGE/3SGTE and Mk3 the ZZ engines. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
01-28-2009, 10:36 PM
Thanks for this ;-)
![]() The crossmember is too fit the gearbox ot the engine ? Which crossmember shall i use ? And what about this steering problem ? I will do photos of everything tomorrow :wink: |
01-28-2009, 10:57 PM
The crossmember is where you normally put the engine on. This normally differs per car/engine combination. That also involves you needing to change the steering as well.
To give you an impression on what you are up to: http://www.billzilla.org/AE863SGE.htm 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
01-29-2009, 12:15 AM
perfect Thanks
New owner from South Africa | MIGGZFSU | 11 | 11,637 |
03-05-2017 08:51 PM Last Post: MIGGZFSU |
Ae86 Owner From Chicago | enano1224 | 16 | 18,228 |
03-03-2014 09:50 PM Last Post: enano1224 |
New Ae86 owner | Mini Steve | 1 | 3,744 |
10-14-2013 09:37 PM Last Post: Mini Steve |
20v Kp Irish owner | conal g | 1 | 3,557 |
12-05-2011 05:08 PM Last Post: conal g |
new irish 86 owner | ssr86 | 2 | 4,160 |
10-18-2011 06:21 PM Last Post: zenki |
