New in RWD, TE71 owner
01-27-2009, 06:12 PM
Ok so the engine is a 2C diesel, 2l
I have to check the gearbox.
I went to a scrapyard and they have a 2l 3SFE. They tell me it comes from a MR2, but from what i found on the net, it did not.
It could fit ? What kind of modification ?
Thanks
01-28-2009, 09:52 PM
3SFE would most probably fit the gearbox, but probably not the crossmember. But adapting the crossmember should not be your biggest problem I guess... Changing over a modern engine require a lot of electronics and looms to be implemented.
The 3SFE is AFAIK not MR2 but rather Carina II and lower spec Celicas. The MR2 MK1 has the 4AGE/4AGZE, MR2 the 3SGE/3SGTE and Mk3 the ZZ engines.
[Image: AEU86 AE86 - New in RWD, TE71 owner]
01-28-2009, 10:36 PM
Thanks for this ;-) Thumbs up!
The crossmember is too fit the gearbox ot the engine ?
Which crossmember shall i use ?
And what about this steering problem ?
I will do photos of everything tomorrow :wink:
01-28-2009, 10:57 PM
The crossmember is where you normally put the engine on. This normally differs per car/engine combination. That also involves you needing to change the steering as well.
To give you an impression on what you are up to:
http://www.billzilla.org/AE863SGE.htm
01-29-2009, 12:15 AM
perfect Thanks Thumbs up!
  New owner from South Africa MIGGZFSU 11 11,008 03-05-2017 08:51 PM
Last Post: MIGGZFSU
  Ae86 Owner From Chicago enano1224 16 17,510 03-03-2014 09:50 PM
Last Post: enano1224
  New Ae86 owner Mini Steve 1 3,601 10-14-2013 09:37 PM
Last Post: Mini Steve
  20v Kp Irish owner conal g 1 3,422 12-05-2011 05:08 PM
Last Post: conal g
  new irish 86 owner ssr86 2 4,011 10-18-2011 06:21 PM
Last Post: zenki
