No.1 fuel injector not working any ideas
03-13-2008, 02:39 PM
well my no 1 injector is not spitting fuel out, do any of you have any ideas of where i should start looking? i already checked voltage at the conector and there was none. what should i do, any help would be awsome
Slide to side worldwide!! |
03-14-2008, 02:51 PM
I believe the injectors are all wired to the same circuit, but the wires come out separately from the ecu (sneaky batch-fire style system). You could try to measure the wire trough from the injector to the ecu. Look for ecu pinouts cause I dont know which ones you need.
Did you measure the voltage with the injector disconnected? Cause if it's shortcircuiting to the head, you will not measure any voltage over it. FABRICA MI DIEM, PVNC! |
03-15-2008, 01:45 PM
yea it has voltage I belive i have a bad injector though so im gonna try to replace it and see what happens. as far as the batch style thing, the no 2 in working fine so i dont think its anything back to the ecu
03-15-2008, 02:33 PM
Just switch some injectors round and see if the problems moves around..Also, try some contactspray on the connections..basic fix, but I've seen it work often.
Brake lights not working | takumi_mt | 2 | 555 |
03-07-2024 03:42 PM Last Post: takumi_mt |
Squeaky seats - any tips? | decryphe | 2 | 888 |
10-18-2023 10:13 PM Last Post: Power_uP |
working out compression ratios | kazi | 2 | 3,411 |
07-16-2019 08:22 PM Last Post: oldeskewltoy |
Dash lights not working. | kazi | 5 | 6,708 |
05-09-2017 12:31 PM Last Post: Ivan141 |
D2 Coilovers any good? | heshan | 18 | 25,461 |
