No dashboard light after retrofitted xenon lights
02-21-2008, 08:08 PM
Hey,
I've installed an xenon conversion kit on my Levin, and that works fine... However the light in the dashboard does not work... Any ideas on how to fix this? 84' Corolla GT Twin Cam AE86 (daily driver) |
02-21-2008, 11:20 PM
Does the rear lights work? Its the same fuse...
Sarcasme is just one of the things I offer Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch |
02-22-2008, 06:05 AM
you need to add a resistor in the wiring loom somewhere, because the resistance of the Xenon at high beam is to low to let the light in your dashboard ligth up.
Only thing is: i haven't got a clue where to add the resistor "It's all about the heart, the people who focus on parts, turbo's and all that stuff...they're just losers." -Shinji Minowa |
02-22-2008, 10:40 AM
I think the Doctor is right but I wouldn't go for adding a resistor, I'd try to seperate the two circuits...
Somehow I think you should avoid using power resistors whenever possible, mainly because I don't find it an "elegant" solution, but also because it will reduce the voltage drop over the head lights and therefore dim them. |
02-22-2008, 10:49 AM
I had the same problem here wit the AE101
what also will work, and you will see, if you fit a normal bulb in the spare empty socket. I will come back to this later with a more clear explanation cheers, Roel |
PWR light issue and no brake fluid after winter storage | magpie | 10 | 2,832 |
20 Valve Blacktop smoking after engine flush - why? | RolanTHUNDER | 2 | 1,464 |
Digital speedometer on stock dashboard | FanIsHere | 0 | 1,499 |
Can you seperate trueno kouki bumper lights into zenki bumper lights? | gh0st | 17 | 8,366 |
12-19-2021 11:58 PM Last Post: gh0st |
Play between steering column and intermediate shaft after manual rack sonversion | DaLanZhu | 5 | 6,982 |
