Nomukens humble AE86 project
07-01-2010, 11:49 AM
Post: #61
Project D Wrote:So finally which engine you enjoy the most, 20v or 16v ? a known Finnish rally engineer once answered when asked about air filters: Have you ever tried to breath trough a sock :wink: 280z '75 audi S4 B5 '99 KE25 '71 |
07-01-2010, 12:40 PM
Post: #62
Good to see the car back on track. How does it feel to drive the 16v again? Better than the 20v?
![]() 5/2018 BMW F22 Coupe 1/1985 Toyota AE86 Levin Coupe |
08-31-2010, 10:05 AM
Post: #63
So, last friday was trackday. Once again the hachi and the 16V rocked the circuit. Had no problems what so ever with the car. Did a few laps behind different S2000's without loosing on them! So yes, I'm quite satisfied. Nevertheless I might sell and build a new project for the next season
enjoy some pics of the day: ![]() ![]() ![]() ![]() ![]() ![]() http://monkeymagic86.wordpress.com |
08-31-2010, 01:17 PM
Post: #64
Nomuken Wrote:So, last friday was trackday. Once again the hachi and the 16V rocked the circuit. Had no problems what so ever with the car. Did a few laps behind different S2000's without loosing on them! So yes, I'm quite satisfied.16v: 1 / 20v: 0 ![]() Mikzu IV Wrote:a known Finnish rally engineer once answered when asked about air filters: Have you ever tried to breath trough a sockDid you have ever see surgeons without mask ? For me, air filter for an engine is exactly the same thing than this. ![]() |
08-31-2010, 01:57 PM
Post: #65
Normally there's a filter on it! Take a look at the pic. But when working on the car, I had to remove it.
[img name=]http://www.aeu86.org/files/16/16vin_815.jpg[/img] When I drive on open roads, there is even an airbox fitted. http://monkeymagic86.wordpress.com |
09-06-2010, 03:11 PM
Post: #66
Some vids from that trackday:
Me following an S2k (cam mounted on helmet): My AE86 in an S2000 sandwich (filmed by an S2000): http://monkeymagic86.wordpress.com |
09-07-2010, 08:33 PM
Post: #67
Great car
![]() Could you post some more pics and details on that roll cage? Philip |
09-08-2010, 05:11 PM
Post: #68
really cool stuff, i enjoyed watching
09-28-2010, 02:47 AM
Post: #69
02-28-2011, 03:25 PM
Post: #70
So let’s keep the built of this up to date. Decided to build a new engine, a 7AGE. After lot's of reading and searching I just pulled the 4AGE out of my AE86 because I’ll need lots of parts from it to get the 7AGE done.
To start with, here’s the 7AFE from a 90’s Carina: ![]() Not that much is needed for the build. Engine block, crank, flywheel and some minor bits. Here’s the block re-bored to 81.5mm and ready to receive a bit of paint. ![]() Some more parts. Lightened and balanced crank, forged rods, ARP bolts, Wiseco 4AGE pistons, new oil pump, new bearings,… ![]() Crank, rods and pistons mounted ![]() ![]() ![]() 7AFE oil pan. Slightly larger than the 4AGE pan ![]() ![]() To avoid oil accumulation in the cylinder head I fabricated an oil return line. Just like on the smallport engines. ![]() ![]() ![]() New OEM head bolts to mount the head ![]() And than started with the timing of the new camshafts. Chose some Kelford. 282 / 278 deg with T3 adjustable pulleys. ![]() ![]() Took me quite some time to get them spot on the timing specs provided by Kelford. New engine, new valve covers. Before: ![]() after: ![]() http://monkeymagic86.wordpress.com |
