OIL:)
12-07-2010, 05:41 PM
Post: #91
OIL:)
Don't remember exactly which element but I think is the fosfor which is in GL5 oil that is doing the damage to old gearboxes. It corrodes copper..
So if it doesn't contain fosfor elements it should be OK. A zašto na eng. ti pričam Uglavnom fosfor u GL5 uljima ubija bakrene sinhrone.. ako nema fosfora nema problema Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62 |
12-07-2010, 06:59 PM
Post: #92
OIL:)
yea i know that... and i think its sulphur but that doesnty mather...
the point is if oil is GL4 AND GL5 regulations it should be safe... right? maybe its better to find just GL4 oil, but ist a bit hard all i found is GL4 and GL5 in one package... so i just asking is it safe to use this combo... it does have GL4 mark so it should be safe... |
02-15-2011, 02:56 AM
Post: #93
OIL:)
Just read through the full oil story.
my decisions engine: Motul 8100 X-Cess 5W40 (rebuild engine after run in) diff: Motul 90PA (rebuild TRD 2 way) gear box: Redline MT90 (clearly says its GL4 and protects syncros) brake fluid: Motul RBF600 Hope this is ok... Do you think its ok to use Motul 90PA with the TRD 2-way LSD? 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
02-15-2011, 11:41 AM
Post: #94
OIL:)
The best oil I have used in a [u:c61afd525f]standard[/u:c61afd525f] lsd is Motul 90PA
02-17-2011, 03:20 AM
Post: #95
OIL:)
Well at least I´m sure it won´t do any harm.
06-16-2020, 04:19 PM
Post: #96
OIL:)
Hello,
I am resurrecting a little bit this topic after a while as i would like to hear your opinions on some new engine oils i plan to try in my AE86 with 185tkm on the clock with unmodfied 4AGE 16v. If someone has real hands on experience this would be great if he can provide some feedback. Thank you. On oil CZ forum they recommended that i try: RAVENOL TSi SAE 10W-40 Millers Oils EE 10w40 ( 7708 ) Motul 6100 Synergie+ 10w40 According oil advisor (Used MR2 W11 as there is no AE86) for 4AGE possible oil options: RAVENOL: RAVENOL TSJ SAE 10W-30 RAVENOL TSi SAE 10W-40 RAVENOL HVE High Viscosity Ester Oil SAE 10W-50 Millers Oils: EE 10w40 ( 7708 ) Trident 5w30 (5995) Trident 10w40 (5991) Classic Pistoneeze 10w30 (8145) Classic Pistoneeze 10w40 (8144) Classic Pistoneeze 15w40 (8143) Motul: 4100 Turbolight 10w40 - according japan page 6100 Synergie+ 10w40 4000 Motion 10w30 - according european page 85' AE86 GT coupe lifetime project since 2005 |
06-17-2020, 03:39 PM
(This post was last modified: 06-17-2020 03:39 PM by Ryo.)
Post: #97
OIL:)
For consideration are these oils as well because of the ester core.
What i am not completely sure if for regular driving (not racing) it is wise to use them. Point is that i don't see any civil versions of ester core engine oils on the market or have not discovered them yet. I saw some PAO+Ester mix oils and also those ester oils are synthetic. I am considering these oils because of recommendation from oil expert from czech oil forum because i try to find better oil that is lubricating engine till it reaches operating temperature. MOTUL 300V CHRONO 10W-40 Millers Oils CFS 10W40 85' AE86 GT coupe lifetime project since 2005 |
06-17-2020, 05:15 PM
Post: #98
OIL:)
Im not that informed about specific oil types, but there is some info to be found out there.
There's this brazilian guy on youtube who does oil testing and both Ravenol and Motul full synthetics did very well. Im using Motul Econergy in my daily driver at the moment. The most important thing with oil is to change it regularly. If you pick a decent oil (do a bit of research) of the correct viscosity then you are doing more than enough for your old 4AGE (and offcourse dont beat on it till the engine reaches operating temperature). FABRICA MI DIEM, PVNC! |
06-19-2020, 05:59 PM
Post: #99
OIL:)
(06-17-2020 05:15 PM)Ivan141 Wrote: The most important thing with oil is to change it regularly. If you pick a decent oil (do a bit of research) of the correct viscosity then you are doing more than enough for your old 4AGE (and offcourse dont beat on it till the engine reaches operating temperature). I am not sure how oil change apply to my driving style as i do probably about 1500km-3000km a year some years back it was even less as i had not time for the car. So perhaps to me it apply to do oil change once a year. But i was not able to read exact info on this topic because i don't have it in owners manual or i don't see it in workshop guide. I decided for now to go with motul 6100 10w40 which is 60-70% syntetic but still a half synth oil with k&n hp oil filter i used denso 90915-yzzj1 to this time but i see the build quality looks poor and all i got last time where made in china and i don't like it. 85' AE86 GT coupe lifetime project since 2005 |
06-19-2020, 08:28 PM
Post: #100
OIL:)
I've always been afraid to poor full synth into older engines that havent ran on it before but I wonder if that is just urban myth.
For those few km's per year you may as well use the best oil you can get.. once a year is more than enough with 3000 k per year. It should probably last longer than that. FABRICA MI DIEM, PVNC! |
trans oil, lsd oil change | Apolan | 9 | 16,898 |
Oil cooler -> low oil pressure | Jan Pedersen | 24 | 30,006 |
4AGE crankcase gas and oil pressure too high, sprinking oil | demogun | 5 | 7,641 |
Oil Presure and what oil i have to use? | CHACAMAN | 4 | 5,304 |
08-27-2008 05:35 AM Last Post: F0Bman |
High engine oil temps - oil cooler discussion | SutteR | 28 | 22,778 |
06-08-2008 11:23 PM Last Post: eight-six |
