OST-013: Massaging a virgin ;)
08-18-2011, 02:35 AM
What have we here.... :cool:
[Image: AEU86 AE86 - OST-013: Massaging a virgin ;)]
Let me introduce to you a virgin :eek:
It is a brand new bare head - no valves, no seals, no wear! Work will begin on Monday Big Grin
This head is one of those being sold here: http://forums.club4ag.com/zerothread?id=93590
Dan -
08-18-2011, 07:35 AM
Thumbs up! lucky number 13 for me - looking forward to the progress Smile
general information - two weeks ago pismir had still one left, in case anyone is interested.
08-18-2011, 10:26 PM
Holy crap! Huh Thumbs up!
08-18-2011, 11:27 PM
banpei Wrote:Holy crap! Huh Thumbs up!
you can say that again as I have another one of these being fitted with OS valves and worked by Loynings Huh
08-20-2011, 02:55 AM
Dan -
08-20-2011, 07:16 PM
Well.... here are some before photos......
intake ports... note @ the top of each photo the mismatched seat. Also note the casting flash
intake #1
intake #2
intake #3
intake #4
The exhaust ports are always rough, note how the port walls are "crowding" the flow.
exhaust #1
exhaust #2
exhaust #3
exhaust #4 - note the mismatch size(one side is taller then the other) of the bowl from the right to the left in this port.... compare it to exhaust #3 and it is more evident
Finally, chamber views. Note in these photos: 1) rough chamber edges(gasket mounting area) where the surface was machined. 2) the mismatched seats. 3) casting flash/flaws
chamber #1 - both views
chamber #2 - both views
chamber #3 - both views
chamber #4 - both views
Dan -
08-21-2011, 12:01 AM
the proverbial other forum Wrote:Are you going to cc the virgin chambers?
GREAT question....... and YES - that way I'll know definatively how large a truly stock combustion chamber is
Dan -
08-23-2011, 01:37 AM
Work begins by checking the combustion chamber volumes. To do this I use a burette
Chamber #4 measures out to 36.5cc.
The other chambers measure out to; #3 = 36cc, #2 = 36.25cc, and #1 = 36.25cc
As I deshroud the chamber, I'll also be equalizing their volume. Here is a photo show chamber #4 deshrouded, #3 chamber in the photo is not yet deshrouded. The chamber walls have been highly polished
Bowl work begins, bowl #8 on the intake side is roughed to size. The factory production process is not perfect, so work is done to blend the bowls, valve seats and the chamber walls to allow maximum flow
Working a bowl the key area is always the roof, here the bowl roof has been cleaned up, the guide narrowed some, and the guide boss has been narrowed substantially
Finally for this post, a before and after on bowl #8
Dan -
08-23-2011, 01:51 AM
So now everyone can know that the stock chamber is between 36cc and 36.5cc, pretty cool to get proper CR Cool
Will you measure chambers after deshrouding ?
Also, can you show us the tool you use for the guide boss ?!
08-23-2011, 02:22 AM
Project D Wrote:So now everyone can know that the stock chamber is between 36cc and 36.5cc, pretty cool to get proper CR Cool
I told my client that I would make sure all the chambers were balanced, so yes... I will have #s after deshrouding
I use a Dremel for all of the porting I do. The guide bosses were reduced using a round cutting bit
I then cleaned up after the round cutter with a few different round tipped abrasive bits
Dan -
  (Catching up) OST-086 MM: Built for Mario oldeskewltoy 2 2,437 10-28-2022 08:23 AM
Last Post: decryphe
  OST-093: My, My, Mystery oldeskewltoy 10 4,604 09-18-2022 02:19 AM
  (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams oldeskewltoy 5 3,178 09-09-2022 09:07 PM
Last Post: Vaptor
  (Catching up...) OST-083: Salvage operation oldeskewltoy 2 2,053 07-11-2022 08:32 PM
  (Catching up...) OST-082: Nope, never again... at least not without all the parts oldeskewltoy 0 1,624 06-28-2022 09:17 PM
