Oil cooler -> low oil pressure
03-27-2011, 02:46 PM
My engine looses oil pressure in the oil cooler. With cooler I get 2.5 bar and bypassed I get 5 and a bit. This is my set up:
Stock 20V BT
RX7 oil cooler
mocal sandwich plate
costum hoses
I'll start off inspecting the cooler again and get som bigger hoses. But how big do the hoses need to be?
[Image: AEU86 AE86 - Oil cooler -> low oil pressure]
03-27-2011, 04:34 PM
What material are you piping? if they go bigger and that why you pressure is getting lower.
03-27-2011, 08:09 PM
They are regular hydrolic hoses. I don't know if they are the reason for the decrease in pressure thats why I asked what size is ok Smile
03-27-2011, 10:48 PM
First of all:
VVT + oil cooler = bad idea !
(the VVT work with oil pressure)
Also, bigger hose = less pressure (Pressure = Force / Area)
If you want to get more pressure, you have to increase the spring rate of the oil pump. (by adding a washer under the spring)
03-28-2011, 01:26 AM
Jan, I'm running -8 AN lines for my cooler, I've never noticed a drop in pressure. I'm running the Mocal, a curved cooler, and the -8
Dan -
03-28-2011, 01:52 AM
Project D Wrote:Also, bigger hose = less pressure (Pressure = Force / Area)
The force exerted on a piston (for example) is pressure x area. But in a
hydraulic circuit, the pressure is equal throughout the system (neglecting
pressure drop due to restrictions). Therefore the size of the hose only
affects the pressure drop due to friction, and in this respect, a larger
diameter hose is better than a small diameter hose.
For those who care, pressure drop in the hoses is proportional to :-
Velocity squared / diameter Tongue
Cheers... jondee86
03-28-2011, 05:56 AM
If it was only showing lower pressure at high RPM, like the rise in pressure was not going up in proportion to the rise in RPM, then with no other restriction/s, the hose size is it.
Have you got the filter & plate plumbed right? The filter's outlet is in its center, the outer ring with all the holes is the input to the filter.
I'd look to an RX7 forum about the cooler, whether its inlet & outlet must be correct, and whether there is a common/known problem with its thermo. valve & restricting flow. Good luck.
03-28-2011, 07:41 AM
The setup is like this: http://forums.club4ag.com/zerothread?id=77707
My hoses are ~2 mm smaler than your -8 AN, Dan. I think I'll go a size up and see if this helps...
If the systems restricktion is in the cooler setup the engine will get full pressure but limited flow.And I'll messure less pressure after the restricktion. This is how I see it but I'm not a flow engineer Smile
A lot of 20V are running oilcoolers and I would have to, to keep it below 100 degr C.
03-28-2011, 10:00 AM
Where is the sensor located?
Andrew
03-28-2011, 10:32 AM
Stock sensor position.
  How to: Repair low fuel warning sender Sanity Clause 3 38,748 05-19-2025 11:05 PM
Last Post: Sanity Clause
  Mocal oil cooler & sandwitch plate ordered Gtsi-R 48 61,313 11-18-2022 02:19 PM
Last Post: FanIsHere
  Oil cooler totta Crolla 0 1,932 07-25-2021 03:25 PM
Last Post: totta Crolla
  Build your own adjustable fuel pressure regulator ;) oldeskewltoy 8 22,949 08-19-2018 12:08 PM
Last Post: AlexKTM
  Silver top low idle AlexFourTwenty 7 11,448 10-16-2017 10:22 PM
Last Post: AlexFourTwenty
