Oil cooler -> low oil pressure
03-28-2011, 05:56 AM
If it was only showing lower pressure at high RPM, like the rise in pressure was not going up in proportion to the rise in RPM, then with no other restriction/s, the hose size is it.
Have you got the filter & plate plumbed right? The filter's outlet is in its center, the outer ring with all the holes is the input to the filter.
I'd look to an RX7 forum about the cooler, whether its inlet & outlet must be correct, and whether there is a common/known problem with its thermo. valve & restricting flow. Good luck.
Messages In This Thread
[] - corolla4agze - 03-27-2011, 04:34 PM
[] - Jan Pedersen - 03-27-2011, 08:09 PM
[] - Project D - 03-27-2011, 10:48 PM
[] - oldeskewltoy - 03-28-2011, 01:26 AM
[] - jondee86 - 03-28-2011, 01:52 AM
[] - allencr - 03-28-2011 05:56 AM
[] - Jan Pedersen - 03-28-2011, 07:41 AM
[] - assassin10000 - 03-28-2011, 10:00 AM
[] - Jan Pedersen - 03-28-2011, 10:32 AM
[] - oldeskewltoy - 03-28-2011, 06:12 PM
[] - Jan Pedersen - 03-28-2011, 09:19 PM
[] - apardal - 03-28-2011, 10:21 PM
[] - assassin10000 - 03-29-2011, 09:30 AM
[] - Jan Pedersen - 03-29-2011, 08:33 PM
[] - jondee86 - 03-30-2011, 08:08 AM
[] - allencr - 03-30-2011, 11:29 AM
[] - Jan Pedersen - 04-02-2011, 09:05 PM
[] - Jonny Rochester - 06-08-2011, 10:48 AM
[] - fax0815 - 06-04-2013, 01:42 AM
[] - gon - 06-04-2013, 08:24 AM
[] - allencr - 06-04-2013, 08:40 AM
[] - Rascal21 - 06-06-2013, 09:32 AM
[] - Deuce Cam - 06-06-2013, 07:36 PM
  Mocal oil cooler & sandwitch plate ordered Gtsi-R 48 55,011 11-18-2022 02:19 PM
Last Post: FanIsHere
  Oil cooler totta Crolla 0 1,553 07-25-2021 03:25 PM
Last Post: totta Crolla
  Build your own adjustable fuel pressure regulator ;) oldeskewltoy 8 20,953 08-19-2018 12:08 PM
Last Post: AlexKTM
  Silver top low idle AlexFourTwenty 7 10,138 10-16-2017 10:22 PM
Last Post: AlexFourTwenty
  Oil cooler kit izanagi 7 8,610 09-20-2016 11:13 AM
Last Post: harkes
User(s) browsing this thread: 14 Guest(s)
