Oil from head to air collector in 4age when drifting left.
04-25-2008, 01:47 PM
Drifting left....
Discharging oil into the intake requires two things... sustained high
rpm to pump a lot of oil up into the cam covers, and a long, high speed left turn. This "centrifuges" the excess oil over to the right of the head where the crankcase vent is located. It is then blown out the vent tube, and finds its way into the air intake. Usually only a problem with the TVIS bigport motors, as smallport and later motors had better oil drains from the head. The tube that you see entering the side of the plenum is channeled internally up a duct that vents into the intake just in front of the throttle butterfly. Some will get sucked into the engine to make smoke Some will drain down to the filter. Google "Cusco" or "Greddy" and "catch can" to see two examples of a universal sealed can. There are other cheaper ones around, available from auto parts supermarkets. Cheers... jondee86 |
Messages In This Thread |
Oil from head to air collector in 4age when drifting left. - jakimany - 04-24-2008, 11:25 PM
Catch me if you can :)) - jondee86 - 04-24-2008, 11:58 PM
Drifting left.... - jondee86 - 04-25-2008 01:47 PM
Fitting Air Con (No PS) to LHD AE86 | pack | 7 | 4,110 |
01-07-2024 11:36 AM Last Post: CCB |
4AGE cylinder head plug removal | Ivan141 | 5 | 2,070 |
Inside of front wheel touches frame rails during drifting | bozu | 3 | 1,762 |
06-09-2022 04:51 PM Last Post: Project D |
Air Cleaner Assembly | Hama86 | 7 | 9,306 |
10-29-2018 03:28 AM Last Post: Hama86 |
AE86 4age engine not starts crank ok backfires to air intake | Ryo | 18 | 17,281 |
08-16-2018 01:36 AM Last Post: Bean |
