Fuel Pressure regulator
05-07-2005, 11:06 PM
Post: #31
I had a look at my stock fuel regulator : It's not attached to a vaacum source . There are only two hose , one to the injectors rail , and the other comming from tank ....??any idea
Filh Filh Save the RWD cars |
05-08-2005, 10:49 AM
Post: #32
You could put a t-junction in the vacuum line that goes to the econometer, or just sacrifice the econometer and use it's vacuum line as a dedicated source. It connects to one of the 3 vacuum terminals at the back of the intake manifold. I think that should provide a perfectly good vacuum source..
05-08-2005, 08:08 PM
Post: #33
oh thanks. I 've noticed a unused vaacum source , near the throttle body
i'll try it . thanks filh Filh Save the RWD cars |
05-09-2005, 12:47 PM
Post: #34
The hose within the screw for adjusting is vac/boost one.
The opposite is for fuel returning. The side one must be connected to the fuel rail. PS: If you turn the regulator 180 angles (top goes bottom) - the things will be easier |
05-09-2005, 07:58 PM
Post: #35
Thanks guys , you helped me a lot with your advices .It's now clear how to fix that FPR. Hope it will work.
Thanks Filh Filh Save the RWD cars |
Build your own adjustable fuel pressure regulator ;) | oldeskewltoy | 8 | 20,840 |
4AGE Fuel Regulator | Alex170984 | 6 | 9,932 |
02-24-2016 05:59 PM Last Post: totta Crolla |
Oil Pressure Query | Alex170984 | 2 | 5,087 |
12-11-2014 01:25 AM Last Post: Alex170984 |
Pressure gathering in fuel tank | Apolan | 9 | 14,750 |
05-18-2014 06:18 AM Last Post: chenfon |
oil pressure high | kawo | 17 | 20,149 |
09-29-2013 12:06 PM Last Post: allencr |
