Omori gauge pulled apart?
08-13-2011, 05:34 AM
Does anyone here know if you can pull apart an Omori gauge??
I brought a set of three, and the glass is a little cloudy and I wanted to pull it apart and clean it up etc. Just wondering if it is possible? And if so, how? (before I break something) lol
Cheers
Smile
08-13-2011, 09:19 AM
Don't think so dude. The part that holds the glass is crimped and holds the lot together. You would destroy it in doing so. I think you can only change the bulbs on some models also.
http://86life.wordpress.com/
  EUDM gauge cluster banpei 22 5,147 08-15-2023 10:48 PM
  Water Temperature Instrument not moving - Sender Gauge Hama86 8 7,769 12-06-2017 06:48 PM
  Analog gauge cluster tech Ivan141 33 43,038 01-31-2016 11:06 PM
  Original gauge with universal fuel sender Komba 4 6,502 01-05-2015 03:27 PM
Last Post: Komba
  problem with defi rpm gauge fax0815 14 26,621 06-13-2012 10:41 AM
Last Post: fax0815
