Os7213 Ae86 Project
11-08-2006, 07:47 AM
Os7213 Ae86 Project
Hi guys im new in this forum and want to introduce myself Smile
My name is Ugo im 22yd and im a Machinist.
Here my project:
(The car remain stock till next summer cause i want all parts ready and do only one complete installation Wink)
Unfortunately its the first time o post here so its hard for to compile all the infos from my origin forum and post it here but some work as been done here and there.
NOTE: TO SEE IMAGE IN BIGGER SIZE JUST RIGHT-CLICK OPEN Wink
[Image: AEU86 AE86 - Os7213 Ae86 Project]
Here the setup for now:
Suspension:
-Shocks Tokico HTS 102 40mm short stroke
-T3 Strut tube+spacers 21.5mm
-Ground control coilovers
-Eiback springs 8kg front 6kg rear
-T3 Top-hat system
-T3 Negative camber plates
-T3 Negative camber blocks
-T3 Tension rods
-Ueo style front lower arms
-T3 4link+panhard
-Ueo style tie-rods end
-TRD rack and pinion
-Tanabe sway bars
-Cusco front tower bar
-Cusco rear tower bar
-Cusco lower bar
-AMT tri-bar
Engine (Not yet complete):
- 4agze small-port head
-20v Itb's
-Toda camshaft 272˚ 9mm lift
-Toda camgear
-Toda spring kit
-Toda under-bucket shims kit
-Megasquirt
Brake:
-Project Mu type Ns brake pads front
-Project Mu D1 specs brake pads rear
-Braided lines
-Brembo slotted ,dip-drilled
Wheels:
SSR speedStar Mesh Ver.B
Here some pictures of under the car after some work and cleaning:
Interior after welding:
And finally some parts:
(Up+Down)
So that it for now hope you enjoy!
Many more to come cause i begin the motor work in few weeks.
See ya.
Ugo
11-08-2006, 10:00 AM
Os7213 Ae86 Project
Whow nice little trueno!!!
Love it! Good luck on the work! Looks like she's in good hands there!
11-08-2006, 10:42 AM
Os7213 Ae86 Project
Smallport head with itbs. Sounds interesting! Thumbs up!
11-08-2006, 11:39 AM
Os7213 Ae86 Project
You dont need a project, you car is allready fantastic! Big Grin Big Grin
[Image: AEU86 AE86 - Os7213 Ae86 Project] http://www.jdmbits.com
11-08-2006, 12:11 PM
Os7213 Ae86 Project
car looks very clean. Wanne see it when you have all your parts installed :-)
11-08-2006, 10:58 PM
Os7213 Ae86 Project
Thank you all for the good comments Wink
The suspension and direction parts will be installed next spring cause i want to wait till i have all the parts to begin the build up!
And for the 16v itb's i will need you help Thumbs up!
See ya guys
11-09-2006, 10:06 AM
Os7213 Ae86 Project
There are several members who installed itb on their 16v heads, but i never heard of putting it on a smallport. Wink
About installing the itbs: might put a question up in the technical section when you are up for it. Smile
11-10-2006, 08:49 AM
Os7213 Ae86 Project
Thank you i will Wink i think the hardest part will be the porting of the itb+flenge and doing a nice flow line with the port!! Oh btw the flenge is nealy done:
I think that gonna rock Wink But the smallport is for me the best way to do porting job! And smallport have some option that i love like the hole for oil return... so why not! After all its the head Thumbs up!
see ya guys!
Ugo
06-28-2007, 03:37 PM
Os7213 Ae86 Project
Hi guys!
I know its been a long time but the project moved a little so here the updates:
I have change my mind for the flenge here the new one:
-Ueo Style tie-rods
-Front Cusco ACL-OS
-Rear Cusco CB
-Cusco Lower brace Type 1
The CB unit is SO LIGHT!
Cusco RS 2ways lsd Respect!
Mounted on Koyo bearings
New Toyota Kouki bumpers, lights, grill, emblem, F/R brakets
New Toyota gas tank gaskets,bolts and rear end bolts+rebuilt calipers
Also got F/R Tanabe sways bars 25.4mm front 20mm rear No pics ;(
And the work begin!!!
Paint
Axels with new Koyo bearings:
The gas tank almost finish:
So like you can see we begin by the rear end Wink
So we will install the new parts, break the lsd and begin the front.
Thanks
Ugo
06-28-2007, 04:33 PM
Os7213 Ae86 Project
It seems that it's going to be a nice and clean project :wink: .Nice work so far, but i would like more details...Is this gonna be your everyday car, or do you build it as a trackday project?
JapanPower
UoP Racing website
UoP Racing videos
