P.A.S.S -- Tokico Authorized Dealer (HTS, HP Shock IN STOCK)
04-16-2008, 11:48 PM
[Image: AEU86 AE86 - P.A.S.S -- Tokico Authorize... IN STOCK)]
P.A.S.S Steel Coilover Sleeve kit with top hat
our sleeve kit is make from our Japan machine shop, Is designed to direct weld on to your strut case with gland nut threading built in. and our top hat is special design only for the corolla.
suspension is one of the most import aspect of our car, do it right the first time, you won't regret it!
Sleeve and top hat kit - $240
P.A.S.S. Top Hats - $50
Swift Coilover Springs - $160 (Spring rate: 4kg-14kg)
Sleeve kit with Swift coilover springs - $390 (Japan option magazine named the #1 coilover springs for competition)
[Image: AEU86 AE86 - P.A.S.S -- Tokico Authorize... IN STOCK)][Image: AEU86 AE86 - P.A.S.S -- Tokico Authorize... IN STOCK)]
Pass Coilover - Bilstein Ss Shocks (life time warranty) Swift Coilover springs/Swift assist springs and Pass Steel Coilover kit
Bilstein inverted design mono-tube gas pressure shock absorbers
Tokico HTS (red) V.S Bilstein (yellow)
Tokico HTS Short Stroke Shocks - $590 (in stock)
P.A.S.S. Coilover with HTS Shocks
Tokico BLues - $199 (in stock)
When you guys ordering swift coilover springs,
info needed
Spring Rates - 4kgmm - 14kgmm
ID of your spring - 60mm, 65mm, 70mm
Length of the spring - 4inch - 12 inch
Swift Assist Springs
Assist springs have two functions. The first is the spring adds a progressive rate to the initial portion of the stroke. This progression can add increased comfort is used on a daily driver coilover setup that has stiff springs installed. It provides racers added softer spring rate progression. Once the assist crushes, the normal spring rate will take over.
The second job is the same as helper springs. They prevent the loss of traction during rebound, and extreme cornering.
Assist springs are designed to repeatedly be fully crushed. Every assist spring crushes to the same height. That allows drivers to change assist springs without resetting the spring perch on coilover without changing ride height.
Price: $126 a set of two
Spring rates: 4kg, 5kg, 6kg
Email me for more detail on the assist springs.
P.A.S.S Racing
148 S.8th Ave, Unit-F
(626)961-6284
City of Industry
SYM@passracing.com
http://www.passracing.com
04-17-2008, 02:20 AM
Good selection you've got there!
Just wondering, how much for a set of Tokico HTS short stroke including shiping to Portugal or UK?
And if you add a pair of Swift front springs (8Kg)?
Regards!
86'LEVIN Track Project
04-17-2008, 06:42 PM
How about some more info on those Billstein shocks. Original application? Custom valvings? etc..
04-18-2008, 05:02 AM
86Pilot - YGM
NoHachi - it's not originally for the corolla, it's custom valving for the corolla short stroke style
P.A.S.S Racing
(626)961-6284
City of Industry
SYM@passracing.com
04-18-2008, 01:38 PM
Hey SYM what about those Swift Assist Springs? My car is for daily driver and I am using BC-Racing Coiloverset (same as Megan Coilovers). I would like more comfortable rides for daily, would this the solutions?
And they are for rear? Sorry I dont know much about this Confused
04-30-2008, 03:11 AM
the assist springs are only meant for front coilover sprigns not the rear. sorry about the late reply email me sym@passracing.com
P.A.S.S Racing
(626)961-6284
City of Industry
SYM@passracing.com
04-30-2008, 10:32 AM
How much would it cost to ship Tokico Blues to Greece, postal code 27100.
Are they stock height or short stroke?
Have you tried any combination of Tokico Blues with Apex springs?
Are Tokico Blues stiffer than stock?
Thanks and sorry for the bunch of questions.
05-01-2008, 10:19 PM
shipping is $151.50 with usps.
tokico blue is stock height, they're pretty much stock replacement.
P.A.S.S Racing
(626)961-6284
City of Industry
SYM@passracing.com
05-02-2008, 03:05 AM
Hey sym im running full Koni suspention, and some no name springs and i want some more stability and not mutch lower then 40mm, what can you rec ?
Ae86 Levin (Kouki)
Year 85
4agte
See her at!
http://www.bilgalleri.dk/html/gal_visbil...ipc=326814
05-02-2008, 04:26 AM
is it Coilover springs? I will recommend Swift Coilover Springs they're much more consistent than other brands
P.A.S.S Racing
(626)961-6284
City of Industry
SYM@passracing.com
  Group A ---- Tomei Authorized Dealer LSD, Pon Cams, Pro Cams Group A 15 23,933 09-24-2012 11:42 PM
Last Post: Group A
  Group A ----- Cusco Authorized Dealer AE86 / KP61 / SW / AW Group A 6 9,478 12-07-2011 09:24 AM
Last Post: Group A
  Tokico Performance HP Struts Spirits Racing 6 9,845 07-24-2011 10:59 PM
Last Post: [Walaki]D`Lair
  Project Mu Brake pads in stock!!! Spirits Racing 1 7,015 06-16-2011 01:12 AM
Last Post: Spirits Racing
  AE86 Kouki Type-RS 1.5 LSD In Stock Spirits Racing 4 6,754 06-13-2011 07:55 PM
