Trouble with idle speed
12-22-2005, 12:09 AM
Ivan141 Wrote:I dont know any thermostat that will raise the temps, but you can use pretty much any corolla thermostat for 4A engines, they're all the same. I think the thermo must be broken the. When driving it is around 1/4. Should bé around 1/3 or even 1/2. Lastnight just left the car sitting outside running for a while. It slowly droped the idle speed to just under 1000rpm, but very slowly, and got warmer too i think. I really think it must be the thermostat, cant imagen of any other thing that might cause this in that exact order. Jón Mar "T3 is good. I'd go with them. And they're red. Red goes faster..." '87 AE86 3dr - Black '87 AE86 3dr - Red '88 AE92 5dr GTi - Black '95 ST205 - Red - sold |
12-22-2005, 11:23 AM
Yep...the symptoms are clear....It's an easy fix. Dont forget to buy a new gasket for the housing while your at it.
No idle below 2000 rpm rich running | Steller Engineering | 3 | 1,409 |
Engine starts/revs but no idle | GenkiMotors | 17 | 7,118 |
exhaust odor/idle MOT issue | Ryo | 7 | 7,225 |
20v silvertop idle issue | AlexFourTwenty | 3 | 5,117 |
Silver top low idle | AlexFourTwenty | 7 | 10,121 |
10-16-2017 10:22 PM Last Post: AlexFourTwenty |
