Propeller shaft universal joint
05-19-2014, 06:03 AM
The universal joint on the propeller shaft(near the diff) is loose and making noise, how do we replace it?
I am told that this is not replaceable and have to replace the whole shaft+joint. |
05-19-2014, 11:05 AM
Just take it to shaft service, mostly they do trucks, but will fix that up no problems.
STL file for the early spec Levin headlight ball joint plastic clip | DaLanZhu | 2 | 827 |
04-26-2025 03:24 PM Last Post: DaLanZhu |
Play between steering column and intermediate shaft after manual rack sonversion | DaLanZhu | 5 | 7,921 |
Steering shaft issue | Ryo | 15 | 14,611 |
11-19-2018 09:52 AM Last Post: Ivan141 |
Original gauge with universal fuel sender | Komba | 4 | 7,093 |
01-05-2015 03:27 PM Last Post: Komba |
Play in prop shaft (diff end) | phill 92 | 14 | 16,315 |
08-07-2012 02:13 PM Last Post: phill 92 |
