Quads Throttle Intake (ITB) on Stock JDM ECU.
06-21-2009, 10:46 AM
Hey Guys,
I'm looking at getting Quads Throttle Intake (ITB) with trumpets along with 266 degrees 8.75 lifts camshafts for my stock 4AGE 16v blue top.
Out of curiosity, would the ^^ above mods work on stock JDM ECU MAP??
Would there be any problems etc ?
The reason i ask is, i would like to ran the ^^ mods for little while till i save up for tuneable ECU down the track.
So far the performance mods i have is Extractors, 2.24" exhaust and HKS Pod filter.
Would be great if someone can elaborate there experience if they have ran the above ^^ mods.
Thanks in advance guys.
Cheers
06-21-2009, 11:19 AM
Im in a very similar situation, have the cams & itbs but no money for management, yet.
Sorry to answer your question, the answer is no, the standard ecu might just be able to handle those duration cams, but not the ITBs together,
06-21-2009, 11:29 AM
yeah, the cams were made to be able to ran the stock ecu, just wondering if its possible to ran the ITB as well as well on the stock ecu.
06-21-2009, 11:45 AM
Do you have MAP or AFM?
The stock ecu should handle up to 264° with lift around 8.5.
I also know someone who had 296° on the stock ecu. He adjusted the fuel pressure and idle was at 2000rpm. Confused
The ITBs should work as long as you have a MAP version.
Speed Industries
Hurdnerwaeldlistr. 73
8808 Pfaeffikon
Switzerland
e-mail: [email protected]
phone: +4155 420 15 69
page: http://www.speed-industries.ch
MSN: [email protected]
We have all the parts your Hachi needs
06-21-2009, 12:07 PM
I'm ranning MAP sensor on mine.
Sweet Smile
Thanks for reply Speed-inc.
Cheers
06-21-2009, 12:10 PM
Have fun with the sweet noise. Thumbs up!
Speed Industries
8808 Pfaeffikon
Switzerland
06-21-2009, 12:16 PM
Where would i locate the MAP sensor line on the ITB? As its Individuals where as the standard plenum, its hooked before the air filter.
Cheers
06-21-2009, 12:51 PM
You need a vacuum tank.
Speed Industries
8808 Pfaeffikon
Switzerland
06-21-2009, 01:18 PM
Sorry for the noob question, where could i get vacuum tank? or would i need to get someone to fabricate one?
06-21-2009, 02:11 PM
No problem, everybody starts somewhere.
You can haveit fabricated or buy one from Golden Eagle.
http://shopping.lightningmotorsports.com...ductid=138
You will also need an adapter plate for the ITB to go onto the 16V head.
Speed Industries
8808 Pfaeffikon
Switzerland
  Digital speedometer on stock dashboard FanIsHere 0 1,405 11-09-2022 01:36 PM
Last Post: FanIsHere
  82mm Stock compression Pistons apardal 4 2,831 11-24-2021 04:26 PM
Last Post: apardal
  20v Silvertop stock ignition timing and fueling maps Lykowsky 5 13,533 07-18-2019 03:52 PM
  Most stock-resembling exhaust for the AE86? DaLanZhu 4 5,642 03-24-2019 04:10 PM
  AE86 4age engine not starts crank ok backfires to air intake Ryo 18 17,373 08-16-2018 01:36 AM
User(s) browsing this thread: 14 Guest(s)
