Question about 4AG 20v Engine Block
05-29-2022, 02:38 PM
Hello guys, thanks for your time and help, I have the following question: I broke my 4AGZE engine due to bad luck and I can no longer find the 4AGZE 3rd generation engine block, I can only find the 4AGE 20v Engine block, my question is can I use this block by placing the pistons and the crankshafts from my 4AGZE on the 20v block crankshaft and get 300-320WHP without modifying the block? I mean without having to change the sleeve?
Thanks http://www.ae86rd.com |
06-10-2022, 05:17 PM
(05-29-2022 02:38 PM)CHACAMAN Wrote: Hello guys, thanks for your time and help, I have the following question: I broke my 4AGZE engine due to bad luck and I can no longer find the 4AGZE 3rd generation engine block, I can only find the 4AGE 20v Engine block, my question is can I use this block by placing the pistons and the crankshafts from my 4AGZE on the 20v block crankshaft and get 300-320WHP without modifying the block? I mean without having to change the sleeve? You should have no issues with using a 20V block.... other then you will also need a 20V oil pan... OR the MRP oil pan (recommend). 300+hp is attainable with the appropriate boost level and tune. Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
Bluetop Engine Rebuild multiple question Goal 150-160hp | Hanzo | 16 | 9,155 |
Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP | mister86 | 12 | 10,966 |
4AGE block differences explained (incl. some eyecandy) | Bean | 46 | 86,766 |
05-05-2019 04:03 AM Last Post: Rocker100 |
BT head with ST block. | CHOPKIN2 | 6 | 7,153 |
02-06-2018 06:27 PM Last Post: mad.matt |
Toda timing info - with good general 4AG timing info too | oldeskewltoy | 0 | 4,275 |
