Wheel geometry and tyre pressure on (near) stock AE86
08-12-2010, 02:55 PM
Hi does anyone have the oem specs for wheel geometry (caster,toe) and tyre pressure, and what adjustments could be made for a dailydriver to enhance the handling. I will get my alignment done soon and i'm looking for a figure to start with.
I realise it would be wise to keep toe at +- 0, but how about the caster setting? Specs of the car are nearly oem, with sporty springs/shocks/bushings and a front tower brace with 185/60/14 tyres. cheers |
08-12-2010, 04:30 PM
tyre pressure 1.9bar (I'm pretty sure about this, I always have the original sticker in my glovebox)
not sure about this: caster: 3.5 or 4 toe: 0 camber -1 and to enhance the handling: camber: -2° ![]() |
Tyre load index | Blaze0010 | 6 | 1,420 |
06-12-2025 04:59 PM Last Post: Blaze0010 |
Digital speedometer on stock dashboard | FanIsHere | 0 | 1,956 |
82mm Stock compression Pistons | apardal | 4 | 3,561 |
20v Silvertop stock ignition timing and fueling maps | Lykowsky | 5 | 14,963 |
Most stock-resembling exhaust for the AE86? | DaLanZhu | 4 | 6,336 |
