Realhachik
05-31-2010, 01:53 PM
Realhachik
don't know why, but clutch is not working
![]() pedal have maximum travel and seems like master cylinder is working visual moves of clutch folk are ok. what's a headache. last thing need to do, to make car move. any ideas? owau no ka "I" |
05-31-2010, 04:27 PM
Realhachik
sounds like you haven't used the car a long time so the clutch disc has got stuck to the flywheel or clutch cover - it's a common problem.
Just start the car in gear (1st), drive it jerking the throttle and kicking the clutch pedal to try and make it slip. eventually it should release and work normally again. It's not hard to do. VISIT OUR NEW WEBSITES!!!! A Tuner's Paradise Automotive Art On Film Dedication To Automotive Perfection Japan Office Tel - (Calls charged at UK National Rate): 0207-193-3979. Mobile (Japan): +81- (0) 90-4133-3825 Fax (Japan): +81-(0) 47-307-4678 |
05-31-2010, 04:30 PM
Realhachik
thnx for idea
car really sit 9 months. before install engine and gearbox I've change clutch disc, just two weeks ago or so. but I'll try your idea. it can be real, because also engine start hard. first I've dead battery and think what problem in it, but yesterday changed to better one and same hard start. I'll make a video on weekend. also will measure clutch fork movement to make sure that it squeezes normally. owau no ka "I" |
06-07-2010, 05:12 PM
Realhachik
shifter finally done and working, as well as all breaks.
but clutch still not. seems like under soaking of slave clutch cylinder. owau no ka "I" |
06-21-2010, 02:00 PM
Realhachik
it's alive :wink:
![]() ![]() stock break pads are suck, need good pads also max.grip lsd kit is a good choice, diff locked everytime. very effective option for stock lsd for just few hundred bucks owau no ka "I" |
06-28-2010, 04:43 AM
Realhachik
Thats's awesome!!!
http://www.super86.co.nz |
06-28-2010, 09:31 AM
Realhachik
those pics are so cool
![]() ![]() 5/2018 BMW F22 Coupe 1/1985 Toyota AE86 Levin Coupe |
06-28-2010, 07:33 PM
Realhachik
Has some potential to be seriously bad for your health... driving without windows that is. Robokill tried it once but was pulled over by a cop.. we then put in the cracked screen to drive it to where it needed to be. On the way some flattened can was launched by a car in front and hit the window...now imagine it not being there... :wink:
09-07-2010, 02:28 PM
Realhachik
I'm already two months driving without rear quaters and rear window
![]() cops sucks, because I've a Technical inspection taloon ![]() old 16V is almost dead ![]() so I put 20V blacktop on a weekend today planned to wire COP's from 1G-FE(1UZ-FE) and start thnx SQ Engineering for water relocation kit, very easy solution with external thermostate, mine is from aw11, but there are a lot of them on the market, even old russian Lada have external thermostates. ![]() ![]() ![]() owau no ka "I" |
09-07-2010, 03:49 PM
Realhachik
